  3. Clarification needed on RC commands
  • Subscribers 94
  • Views 15390
NAADHAN
NAADHAN over 17 years ago
                       In our project we go for a netlist to netlist optimisation using rc-compiler  (V8.1).I need a clarification on the following commands
                        1)  "tns_opto true"
                        2) "endpoint_slack_opto true"
These to options were tried seperately in 2 of my runs .....but they didnt have much of an impact...no change in the TNS and WNS of both the results...... Pls clarify on this... Am not clear about what the second option does....
Thanks & Regards,
NAADHAN
  • grasshopper
    grasshopper over 17 years ago
    HI Naadhan,
    both attributes serve the same purpose but endpoint_slack_opto is the old name. If your design was meeting timing then this attribute will not do anything. The attribute simply ensurse that the tool continues to optimize beyond the crtical paths in cases where the critical path does not meet timing
     gh-
  • NAADHAN
    Hi GH:-).... i got what these options meant...but my result didnt change with & without these options...  get the same Worst Negative Slack and Total Negative Slack...Timing is also not met... Though it was a bit overconstrained run we expectd atleast the TNS to reduce but we didnt see it in the results...
