  3. Generating routing statistics
  • Subscribers 93
  • Views 15530
archive over 20 years ago
I am looking for a way to generate the net lenght for power, clock and signal nets per layer. Does anybody know a way to do that and is there any pre-requisite. I assume that the DEF attribute are all that is needed.
Typically I would like to generate a table with
METn
Thanks for your help,
Eric.
Originally posted in cdnusers.org by evenditti
    Hello Eric,
    You can get this summary from the encounter GUI:
    Design -> Report -> Summary
    You can generate a Text or HTML report.      The following information in the text output is at the bottom of the report.   This is not broken out exactly the way you are looking for though (clk net, special net, signal net)
    Elvis
    Wire Length Distribution
    Total M1 wire length: 0.0000 um
    Total M2 wire length: 1006351.7600 um
    Total M3 wire length: 1294334.0600 um
    Total M4 wire length: 1153091.0800 um
    Total M5 wire length: 1069123.9400 um
    Total M6 wire length: 1022576.4600 um
    Total M7 wire length: 748782.6200 um
    Total M8 wire length: 11216.9800 um
    Total M9 wire length: 37798.3800 um
    Total wire length: 6343275.2800 um
    Average wire length/net: 57.3642 um
    Originally posted in cdnusers.org by elvis
    Hello Elvis,
    I have been digging into this and in fact to do what I want I need a few reports.
    The one you mention give me global usage per layer but not a breack down by category.
    The trick without advance scripting is that there is no report per category or net giving both special and regular nets so I use the following reports
    For power nets
    reportPowerStat -detailed -wireonly
    For non power nets
    reportWire -detail 0
    The first report is not very comprehensive as it uses layer number instead of layer name but it is not too difficult to handle.
    The second report will have all your routed (included power for tie high/low) and is very usefull if you have some kind of naming convention or generate an associate report (through scripts) classifying the nets per category.
    And then finally I use a perl script to process all that.
    If anybody has a better solution let me know.
    Eric.
