  3. Multiprocessor ADE Option
  • Subscribers 94
  • Views 16776
piters
piters over 17 years ago
 Hi everyone,
 after installing a Cadence IC on a DELL workstation (2xQuad CPUs), I have noticed, while simulating a circuit with ADE L, that  not all of the CPUs are in use. Do I need additional software, or license feature to fix hardware resource usage? What might be a potential cause?
 Thanks in advance!
  • aplumb
    aplumb over 17 years ago
    You're going to have to be more specific. Which version of Virtuoso are you using (IC5.1.41 or IC6.1.3)? Which version of Spectre are you using (ancient ships-with-IC5.1.41 or more current MMSIM 6.2, 7.0 or 7.1)? What sort of Spectre licenses do you have access to (MMSIM tokens or Spectre-only) and how many? Also, talk to your AE. They can fill you in on all the gory details. Andrew.
  • piters
    *virtuoso -W => sub-version IC6.1.3.1
    *spectr -W => sub-version  7.0.1.076
    Token Information:
    License Analog_Design_Environment_GXL:
            Capability                 Tokens  Version  In Use
      Analog_Design_Environment_GXL       2     6.10      N
      Open Simulation System              2     6.10      N
      adegxlDCM                           1     6.10      N
      adegxlMTS                           2     6.10      N
      adegxlMismatchSensitivityAna        1     6.10      N
      adegxlMspsEst                       1     6.10      N
      adegxlNominalOptimizer              6     6.10      N
      adegxlYieldAnalysis                 10    6.10      N
      Total tokens checked out for current user:  0
      Total tokens:            12
      Total available tokens:  12
    License Virtuoso_Layout_Suite_GXL:
      Analog_Auto_Placer                  8     6.10      N
      Cell_Planner                        4     6.10      N
      Custom_Digital_Placer               2     6.10      N
      Floorplanning                       4     6.10      N
      Layout_CE                           4     6.10      N
      Module_Generator                    2     6.10      N
      Open Simulation System              4     6.10      N
      Space_based_Automatic_Router        24    6.12      N
      Space_based_Automatic_Router_>250K  48    6.12      N
      VLS_GXL                             4     6.10      N
      Total tokens:            24
      Total available tokens:  24
    i need to know if the performance problem is caused by Cadence software (lack of apprioprate package, license).
    Kind Regards,
    peter.
  • aplumb
    You're going to have to look at the output of 'lmstat -a -c 5280@' to see what count of Spectre and/or 'Virtuoso_Multi_mode_Simulation' licenses you have. One quick way to see if your licenses are current enough for multi-threaded sims: open up ADE L and see if the 'Setup - Turbo/Parasitic Reduction' menu option is accessible. If it is then you have the licenses; open it up and click the 'Turbo' switch. Check your 'spectre.out' log files for phrases like 'number of threads used' to see what's being used if you don't go with the default 'Auto' number of threads. Also note, you probably won't see one spectre process per thread. You should see >100% numbers show up in 'top'. Hope this helps! Andrew.
  • aplumb
    Sorry about the formatting. This forum doesn't like return characters as entered via Safari on Mac OS X. I'm told they're looking into it... A.
  • tkhan
    tkhan over 17 years ago
    i noticed a message in my output log saying that multithreading won't be enabled because i have less than 256 bsim4 instances in my schematic. maybe you're getting the same message?
  • piters
     Thank you for your replies. I think I have found the answer to all the bothering questions. Namely, check out the link:
    http://www.ee.ucla.edu/~shervin/ic/cadence/multi.txt
