  3. No metal2 antenna info in Lef file from Abstract Genera...
  • Subscribers 94
  • Views 15943
No metal2 antenna info in Lef file from Abstract Generator
Vaishali
Vaishali over 17 years ago
I generated a lef file using Abstract Generator. One of the pin of macro is on metal3 and the net connected to it has small amt. of metal2 routing. The tool is dumping antenna info of metal3 but not of metal2.
I looked for other pins which has routes in other layers, the antenna infomration is dumped out properly for them.
The issue is only with metal2. The technology lef that I m using as a input to tool has all the antenna parameters defined  for layer metal2.
What could be the possible reasons for it?
Thanks & Regards,
Vaishali
  • wally1
    wally1 over 17 years ago
    Hi Viahsali,
    Only the metal that is on the same layer or above as the pin layer are needed to model the process antenna effects for a block. This is because when you calculate the process antenna effects for metal2 there will not be a connection into the block because metal3 has not been processed yet, so any metal2 inside the block will not have an effect outside the block.
    For more information on hierarchical antenna calculations see the following:
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/lefdefref/lefdefref5.7/PAE.html#1036921
    Brian
  • Vaishali
    Thanks Brian for the answer. It was really helpful.
    Vaishali
