  3. Why do we go for virtual clocks??
  • Replies 7
  • Subscribers 93
  • Views 18307
NAADHAN
NAADHAN over 16 years ago
Hi ,
Can anyone pls explain me why we need virtual clocks in our designs ??
Thanks& Regards,
NAADHAN
  • grasshopper
    grasshopper over 16 years ago
    Hi Naadhan,
    not all designs need virtual clocks but, more often than not, they usually are required to model on-chip to off-chip interactions.
    For example, logic driven by a PLL on-chip could have completely different characteristics than the clocked logic it connects to off-chip and we need to model this accurately for the I/O timing to be reasonably accurate.
    There are many other applications but usually they involve on / off chip modelling situations but certainly not limited to them
    gh-
  • NAADHAN
    Thanks a lot grass hopper :-)..... u have mentioned that it is not only limited for modelling io timings....Can you tell me where else this Virtual clocks  be used in the design ...
    Thanks&Regards,
    NAADHAN
    archive over 16 years ago
     Hey Naadhan,
     Virtual clocks can also be used within a design to constrain a purely combinational portion of the design. Namely, you create a virtual clock and then set input and output delays on the purely combinational block, with respect to that virtual clock.
    Hope this helps,
    A.
  • frankz
    frankz over 16 years ago
     Once you have a hierarchical design, you should use virtual clock for your modules after CTS is done.
  • NAADHAN
    Hi Alex...thanks ... your point is very clear ;D
    Regards
    NAADHAN
  • NAADHAN
    Hi Franki..."Once we have a hierarchical design ....we should use virtual clock for our models after CTS " ------> can you elaborate it pls? am not clear ...
    Thanks & Regards,
    NAADHAN
  • frankz
     The postCTS clock are not ideal, and you need to set clock latancy for 'input--> reg' and 'reg--> output' timing path.
    You need to set virtual clock to time the IO timing path based on this point.
