  3. Need guidance to develop a script to get the number of logic...
  • Subscribers 97
  • Views 23209
Need guidance to develop a script to get the number of logic levels from an encounter timing report..!
NAADHAN
NAADHAN over 17 years ago
Hi all,
                   I need to develop a script for finding the number of logic levels in a timing report from encounter.I should give a timing report as an input and i need to get the number of logic levels(Combinational) as an output.Can anyone Pls guide me in developing  it?
Thanks and Regards,
NAADHAN
  • maven7783
    maven7783 over 17 years ago
     Hi NAADHAN,
    You can use the awk command to get it
    awk '{print $4}' filename
    $4 is the cell column the timing report.Direct the output of the above command to file where use numbering commmand of vi and find out the logic levels.
    OR
    Before you output timing report change the global report_timing_format to only cells....which will give only cells...
    Hope this helps
  • BobD
    BobD over 17 years ago
    On thing that may also be useful here is the ability for the report_timing command to return a *collection* instead of a textual report.  The collection can then be programmatically queried for all sorts of information, including the number of timing points.  Here's how that would work:
    1. First, add the "-collection" switch to the report_timing command, and capture it as a variable called "c":
      encounter 39> set c [report_timing -collection]
      0xdd
    2. Next, you can query which properties are present for the collection. You should see all kinds of fields present, but "timing_points" is the one we can use to determine the number of levels of logic:
      required_time                       | 4.646
      setup                               | 1.104
      slack                               | -0.503
      slackPercentile                     |
      slackSensitivity                    |
      slackStdDeviation                   |
      timing_points                       |  <--
    3. We can get the timing_points field with the "get_property" command:
      encounter 41> get_property $c timing_points
      0xe5
    4. Each of the instances in the timing path has 2 "points".  These can be iterated through and queried, but if you wanted to get the number of logic levels rather than the number of timing points, you could roughly divide by 2. This path has 10 instances:
      encounter 42> sizeof_collection [get_property $c timing_points]
      20
    Hope this is helpful,
    Bob
  • NAADHAN
    Hi Bob ,,,,thanks a lot for your suggestion... i will start working on this from today onwards ;D.... Could you elaborate on querying for properties ??? am not clear on that...
    Thanks & Regards,
    NAADHAN ;D
  • VedGupta
    VedGupta over 11 years ago
    Hi Bob , can you describe , how can i query for properties for collection ?
  • BobD
    BobD over 11 years ago
    Use "report_property" and "get_property".
    There is a Rapid Adoption Kit for this:
    Usage of collections in EDI & ETS, version 11.1 and above
    Hope this helps!
  • kazad
    kazad over 11 years ago
    Hi Naadhan
    You can try the following 'getLogicLevel' procedure which is used in the 'generateSlackReport' procedure.
    Please let me know if you see any issues.
    Khandaker
    # Procedure to get logic level from a given collection of timing points
    proc getLogicLevel {timingPointsColl} {
    set currentInst ""
    set pathInstList {}
    foreach_in_collection timingPointObj $timingPointsColl {
    set pinObj [get_property $timingPointObj pin]
    set objType [get_property $pinObj object_type]
    if {$objType == "pin"} {
    set instObj [get_cell -of_objects $pinObj]
    set instName [get_property $instObj hierarchical_name]
    } else {
    set instName [get_property $pinObj hierarchical_name]
    if {$instName != $currentInst} {
    lappend pathInstList $instName
    set currentInst $instName
    set logicLevel [llength $pathInstList]
    return $logicLevel
    # Procedure to generate timing slack file
    # Usage: generateSlackReport -mode <setup | hold> -slackTarget <slack_target> -file <report_file>
    proc generateSlackReport {args} {
    # Defaults
    set slackTarget 0.0
    # Get setup/hold
    if {[regexp {\-mode} $args]} {
    set analysisMode [lindex $args [expr [lsearch $args -mode] + 1]]
    # Get slack target
    if {[regexp {\-slackTarget} $args]} {
    set slackTarget [lindex $args [expr [lsearch $args -slackTarget] + 1]]
    # Get slack file name
    if {[regexp {\-file} $args]} {
    set slackFile [lindex $args [expr [lsearch $args -file] + 1]]
    # Help
    set helpString "Usage : generateSlackReport \
    \-mode <setup | hold > \
    \-slackTarget <slack_target> \
    \-file <slack_file_name> \
    \-help"
    if {[regexp {\-help} $args] || $args == ""} {
    puts $helpString
    return 0
    # Main code
    # Open slack report file
    set f [open $slackFile w]
    # Set command set for setup/hold analysis
    if {$analysisMode == "setup"} {
    set rptTimingCmd {report_timing -from [all_registers -clock_pins] -to [all_registers -data_pins] -max_slack $slackTarget -late -collection}
    } elseif {$analysisMode == "hold"} {
    set rptTimingCmd {report_timing -from [all_registers -clock_pins] -to [all_registers -data_pins] -max_slack $slackTarget -early -collection}
    } else {
    puts "ERROR: Unsupported analysis mode!"
    return 0
    # Report header
    puts $f [genLine -width 100 -char "="]
    puts $f [format "%-10s %-30s %-8s %-8s %-25s %-50s %80s" "Slack" "View Name" "Level" "Skew" "Clock Domain" "Launch Point" "Capture Point"]
    # Create a collection of timing paths
    set timingPaths [eval $rptTimingCmd]
    if {[sizeof_collection $timingPaths] > 0} {
    # Iterate over the set of paths, and process them one at-a-time
    foreach_in_collection path [sort_collection $timingPaths {slack}] {
    set timingPointsColl [get_property $path timing_points]
    set logicDepth [getLogicLevel $timingPointsColl]
    set startPoint [get_property [get_property $path launching_point] hierarchical_name]
    set endPoint [get_property [get_property $path capturing_point] hierarchical_name]
    set launchClock [get_property [get_property $path launching_clock] hierarchical_name]
    set captureClock [get_property [get_property $path capturing_clock] hierarchical_name]
    set launchClkEdge [lindex [split [get_property $path launching_clock_open_edge_type] {}] 0]
    set captureClkEdge [lindex [split [get_property $path capturing_clock_close_edge_type] {}] 0]
    set launchClockTime [expr [get_property $path launching_clock_latency] + [get_property $path launching_clock_open_edge_time]]
    set captureClockTime [expr [get_property $path capturing_clock_latency] + [get_property $path capturing_clock_close_edge_time]]
    set skew [expr abs($captureClockTime - $launchClockTime)]
    set slack [get_property $path slack]
    set viewName [get_property $path view_name]
    puts $f [format "%-10s %-30s %-8s %-8.2f %-25s %-50s %-80s" $slack $viewName $logicDepth $skew "${launchClock}(${launchClkEdge})->${captureClock}(${captureClkEdge})" $startPoint $endPoint]
    close $f
    # Procedure to generate line seperator
    # Usage: genLine -width <width_size> -char <character_name>
    # Example: genLine -width 20 -char "#"
    proc genLine {args} {
    # Default
    set char "-"
    # Get width
    if {[regexp {\-width} $args]} {
    set width [lindex $args [expr [lsearch $args -width] + 1]]
    # Get char
    if {[regexp {\-char} $args]} {
    set char [lindex $args [expr [lsearch $args -char] + 1]]
    # Help
    set helpString "Usage : genLine -width <width> -char <character>"
    puts $helpString
    return 0
    # Main code
    for {set i 0} {$i <= $width} {incr i} {
    lappend print_list $char
    return "[join $print_list $char]"
