  3. tip of the week: improve run time during initial placem...
  • Subscribers 93
  • Views 15807
tip of the week: improve run time during initial placement
archive over 19 years ago
You can cut your run time by up to 3x (for 500k instances) by not doing scan recordering during placeDesign.  You can do the following
. SETUP UP YOUR SCAN IN & SCAN OUT
setPlaceMode -noReorderScan -modulePlan
placeDesign -with_your_own_option
scanReorder
optDesign -preCts
With the above flow, the run time is reduced at the same time congestion & timing do not get worst.
li siang
Originally posted in cdnusers.org by lisiang
    Hi Li Siang,
    I tried out your suggestion, but does not see improvement. The design is bigger than 500K during placeDesign. Maybe I am using scandef. There are many scan chaisn due to the use of scan compressor. I think it is a easier flow to use scandef than to define scan-in and scan-out in Encounter especially with scan compressor the scan-ins and scan-outs are at defined at hier ports.
    Do you have any idea why disable scan reordering can make placeDesign with modulePlan run faster?
    Eng Han
    Originally posted in cdnusers.org by EngHan
    i assumed you are using -inPlaceOpt with -modulePlan.
    -modulePlan wil run placement multi-time with the -inPlaceOpt to improve timing. Each re-placement will cause a scan recordering. Thus turning off the scan recordering will save some run time. If you design is not timing critical, then the re-placement might not happen and you might not see the run time saving.
    li siang
    Hi Li Siang,
    I am not using "-inPlaceOpt" with -modulePlan. I using optDesign after placeDesign. This is the reason why I don't see improvement in runtime.
    In your experience, do you prefer to use "-inplaceOpt"? Somehow it appear to me that running in two steps give better result.
    Eng Han
    it is design dependent. In general -inPlaceOpt with -modulePlan works pretty well due to the replacement & re-opt. In some of the block i did, i found the following woked better (gave better timing)
    placeDesing -modulePlan
    optDesign -preCts
    placeDesign -incr
    optDesign -preCts
    li siang
