  3. How to fix all registers in encounter
  • Subscribers 93
  • Views 17373
archive over 19 years ago
Does anyone know of any automatic way to fix all registers in encounter after CTS?
It seems like a pretty common task, and I thought I would ping the community before I start digging for a way myself.
Manzur.
Originally posted in cdnusers.org by myazdani
    proc fixCellPlc {} {
    foreach instName [dbFindInstsByCell SDFF*] {
    dbSetIsInstPreplaced $instName 1
    you have to change "SDFF*" to your reg master name type.
    li siang
    Originally posted in cdnusers.org by lisiang
    Hi Manzur,
    I think it is highly advisable to preserve all the clock network (tree) once you have satisfied CTS results .
    Aside the good tcl from li siang for only FF`s ( Does your CTS covers all FF's in your desing ??), i recommend to use .
    #-- Change clock status (PLACED -> FIXED)
    changeClockStatus -clk FE_CTS_ROOT/Z -fixedBuffers -fixedNetWires -useClock
    NOTE : useClock switch has special treatment in routing ( if you specify special attributes like extra space ,top metal layers etc..)
    like Ex .
    #-- Clock routing
    setAttribute -net {@CLOCK} -weight 20 -preferred_extra_space 1
    FYI .
    -fixedBuffers
    Changes the placement status of buffers, inverters, flip-flops, and gating cells from PLACED to FIXED.
    -fixedLeafInst
    Changes the placement status of leaf instances from PLACED to FIXED.
    -fixedNetWires
    Changes status of wires in clock nets from ROUTED to FIXED.
    -fixedNonLeafInst
    Changes the placement status of non-leaf instances from PLACED to FIXED
    With Regards,
    CH.MOHAN KUMAR
    Originally posted in cdnusers.org by mohanch007
    Hi Manzur,
    like Ex .
    #-- Clock routing
    FYI.
    -fixedBuffers
    -fixedLeafInst
    -fixedNetWires
    -fixedNonLeafInst
    With Regards,
    CH.MOHAN KUMAR
