  3. RC TNS optimization is not enough
  • Subscribers 94
  • Views 15510
Ran Fisher
Ran Fisher over 17 years ago
I'm synthesizing with "tns_opto" attribute set to true. I still don't like the results I'm getting. I have many paths with the same timing violation. The first one I see isa real one I expected, the second one is not real and I have proved it.
 How did I prove it? I created a special path group for this path and did an incremental synthesis. The overall worst path was improved by 5ps, and the path I put in a special group was improved by 70ps. My frequency target is more than 1GHz, so these small numbers are significant.
 I'd like to have synthesis results where the really bad paths are distinguishable.
I think the problem is that "tns_opto" actually works on endpoints only, and the two paths in question indeed share the same endpoint. I'd like to improve the other paths because I think I can do some special work in P&R (maybe useful skew on the start point), or special routing etc.
Encounter supports "critical range", like DC does. "tns_opto" is not exactly the same. Has anybody ever solved this?
    archive over 17 years ago
     Hey Ran,
     I'm not sure I understood how you conclude that the path that improved by 70s is a false one but in any case, if you are sure that a path that is reported as a violator is not a real problem in your design then you should definately do a 'set_false_path' on it. This will prevent the tool from trying to optimize it.
     Regarding tns_opto, maybe you could try to be more specific when you group the paths. I mean something like this:
    group_path -name <name_of_group> -from <startpoint> -to <endpoint> -critical_range <usually about 10-20% of target max delay> -weight 5
     If you make the critical_range value rather large the tool will try to optimize more paths (at the expense of runtime). After doing an incremental compile you should see that all paths in the group improve their timing.
    Hope this helps,
    A.
