  3. Cause of long timing delays in Encounter Timing
  • Subscribers 95
  • Views 15290
jkang
jkang over 17 years ago
I have a timing path (several actually) that seem to be unusually long. I've tracked it to one AO22 cell that has a huge timing arc (~40ns) from its A1 -> Z. I want to know what's causing this; how is the tool calculating the delay?
I've been messing around with get_property, report_property and a few other DB commands but I am kinda groping in the dark here. Is there a way to tell how the delay is being calculated? Specifically, calculated input transition times, dot-lib look-up table and the calculations for output delay.
  • frankz
    frankz over 17 years ago
     Read the timing report and check on the slew and cap load for this instance.
  • Kari
    Kari over 17 years ago
     You may also want to report net delays and cell delays separately; report_timing -net will do this. It could be you have a long route on this pin which is really causing the delay. Also, using the Global Timing Debug in Encounter can help you find the cause.
