  3. constraining no. of metal layers in Cadence SoC encount...
  • Subscribers 95
  • Views 16168
constraining no. of metal layers in Cadence SoC encounter
Layouts
Layouts over 17 years ago
Hi all! Please let me know if there is any form in the tool Cadence SoC encounter where we can declare no. of routing layers for our design with limited no. of metals say 5. But my tool & Technology supports 8 Layer Metal. One solution what I found is during design Import we can call technolgy file(.lef) of say 5 Layer metal. Is there any other place in the entire flow where I can constrain say to 5LM in the tool? Thanks in Adv!
  • BobD
    BobD over 17 years ago
    The "setMaxRouteLayer" command is intended for this. It informs all of the components in the system that although there are (for example) 8 metal layers in the technology LEF that only 1-5 are to be used for routing.
    Hope this helps,
    Bob
  • Layouts
    Dear Bob, Thanks for reply. Now please tell me where I have to use this command in my flow? Can I declare this command at any stage in my flow or I have to declare this after or befare some particular stage? Thanks Jit
  • NAADHAN
    NAADHAN over 17 years ago
    Hi ,
                        1. In the place stage you will be using trialroute for nets so there you can use
                                                              setTrialRouteMode  -maxRouteLayer  <value>
                                                              setPlaceMode -maxRouteLayer <value>
                        2.In CTS(If you actual routing of CTSnets later)
                           In CTSspecfile dont forget to include
                                             TopPreferredLayer      <value>
                                             BottomPreferredLayer   <value>
                          3.set_attribute -net <netname> -top_preferred_routing_layer <value> --bottom_preferred_routing_layer <value>
    Hope this helps you !
    Thanks n Regards
    NAADHAN
  • Kari
    Kari over 17 years ago
     Naadhan lists some very good specific layer controls for various parts of the flow. Sometimes, for example, you want your clocks to be on even fewer layers than the rest of the design.
     If you are just using setMaxRouteLayer for everything, just specify it at the very start of your flow. It will be followed for all steps.
