  3. Early Rail Analysis and Rail analysis
  • Subscribers 94
  • Views 18912
atwork
atwork over 17 years ago
Hi
Do I need to run ERA before runing RA?
In my pull-down menu, I cannot click on RA after loading the database. Do I need a different level of Encounter licence?
In the ERA menu, there is an input for using instance Current file. How is this file generated?
I have a file which has each instance power information. Can this file be used?
thank you
  • BobD
    BobD over 17 years ago
    I asked someone more familiar with Rail Analysis, and they advised that in order for the menu pick for RA to be un-greyed, a Power Grid Library needs to be generated.  In order for a Power Grid Library to be generated, first go to "Power->Rail Analysis->Power Grid Library->Set Power Grid Library Mode..." then "Create Power Grid Library" then Rail Analysis should be un-greyed.
    I wanted to test this before passing the advice along to you, but I didn't have a design handy with the required technology files and layer mapping files.
    If your get a chance to try this, please report back and let us know if it resolved your issue.
    Hope this helps,
    Bob
  • Srinath VLSI
    Srinath VLSI over 6 years ago in reply to BobD
    Dear BobD, am doing my research in management of PDN.
    I read some papers claiming that use of Higher metal layers would reduce IR drop.
    But still we have some IR drop in contemporary designs .
    Also, there are also some floorplanning solutions which overcomes these drops.
    Can you please comment on this or explain it .
