  3. How to retrieve the variable which is defined in the SOC...
  • Subscribers 93
  • Views 16644
How to retrieve the variable which is defined in the SOC Encounter configure file ?
archive over 19 years ago
I have some variable defined in my SOC Encounter’s configure file, such as set BLOCK CDMA200 set SPC_DIR /user/tom/3gmodule/CDMA In the Encounter shell environment, how can I retrieve the variable ${BLOCK}, and use it in my other scripts, I ask this question because I found it in inconvenient that I must defined some of variables both in the configure file and in my tcl scripts.
Originally posted in cdnusers.org by aidans
    It looks like the variable defined in the .conf file are only available locally (ie, within the .conf file). If you want to be able to refer to variables set in the .conf file you could defined them as globals:
    design.conf:
    set rda_Input(ui_gen_footprint) {1}
    global bob
    set bob test
    encounter> loadConfig design.conf
    encounter> puts $bob
    test
    There may be other ways to retrieve some of the things you'd like to extract from the .conf file via FE db commands. For example CDMA200 might be the name of the top cell in your design so you could query that with an FE TCL command:
    encounter> dbgDesignName
    CDMA200
    Hope this helps,
    Bob
    Originally posted in cdnusers.org by BobD
    Thanks Bob, It works well.
    moreover, I have another question.
    This is related to our golen.conf
    in the config fie there is this lines
    set rda_Input(ui_netlist) "$NETLIST"
    in our user defined tcl scripts, I write this:
    loadConfig golden.conf
    Now the question is, Is there is a way I can set the variable *NETLIST* in the user defined scipts. so that I don't need to copy the golden.conf and modified it.
    I tried the golbal thing you give to me,
    global NETLIST
    set NETLIST /path/to/verilog_file
    It failed to retrieve the $NETLIST
    encounter 6> loadconfig ../spc/tcl/golden.conf
    Reading config file - ../spc/tcl/golden.conf
    can't read "NETLIST": no such variable
    Anyway, I just try to setup more efficient design flow.
    Thank you in advance.
    Ah yes- I follow what you're trying to do. I think it's fairly common that you want to keep almost everything in a project/golden conf file, but you want to change just a couple of things (like the netlist or timing constraints or whatever).
    I usually do that this way:
    loadConfig golden.conf 0
    commitConfig
    The key is the "0" after loadConfig which is conceptually the same as what happens when you load a conf file via the GUI. Then clicking "OK" on the Design Import is the same as commitConfig.
    Do you think that will suit your needs?
    Yes, This is what I am looking for. Thank your for your support. You really explained it clearly. Thank you again.
