  3. How to automate the routing of special nets ( nets with...
  • Subscribers 93
  • Views 15337
How to automate the routing of special nets ( nets with more width ) in the encounter ?
KVBABU
KVBABU over 17 years ago
 Hai every one,
In my design , i have a requirement of  drawing net at many places . In some places , i have to employ double width using non-default rules. But, in some places , i need the same net of regular width . In such a case, the pieces of net with double width are treated as special and others are treated as regular .So the router can not able to join them . Could you suggest me a way automate the process.
KVB
  • asedehi99
    asedehi99 over 17 years ago
    any luck
  • asedehi99
    i mean to ask that as a question
  • Kari
    Kari over 17 years ago
     KVB,
    A net doesn't need to marked SPECIAL just because it uses a NONDEFAULT rule. Did you accidentally have "Force Special" turned on when you drew those routes? Or, is this really a SPECIALNET - power, ground, etc...
    - Kari
