  3. SoC Encounter DB Access - Power/Ground Nets
  • Subscribers 95
  • Views 1114
dbekiaris
dbekiaris over 17 years ago
Hello everybody I am using SoC Encounter 7.1 and I use DB Access methods for layout extraction. Whereas I am extracting the wire information about the wires of the signal nets, there is a problem with the power nets of the design. In perspective, whenever I try to extract wire information about the specific nets, even after doing detailed RC extraction including special nets, there are no wires reported. The 'Verify Connectivity' tool shows no problem with the connectivity of power rings, stripes and followpins. Is there anything I can do with this issue ?I would be grateful if somebody could help me. Thank you very much in advance
  • dota
    dota over 17 years ago
     there is a simple script which maybe help you.
    dbForEachFPlanStrip [dbHeadFPlan] stripPtr {
           set name [dbStripName $stripPtr]
            if { $name == "VDD" } {
                   dbForEachStripBox $stripPtr stripBoxPtr {
                           set netPtr [dbStripBoxNet $stripBoxPtr]
                           set netName [dbNetName $netPtr]
                           set shape [dbStripBoxShape $stripBoxPtr]
  • dbekiaris
    Thank you very much for the immediate response!However, I have run several similar codes using dbStriBoxNet and dbInfoStripBox but still I cannot see wires as in the classic signal nets. Anyway, I would like to thank you again for your help! Kind Regards
