  3. db command to get power pin co-ordinates for a given Ma...
  • Replies 11
  • Subscribers 95
  • Views 25265
db command to get power pin co-ordinates for a given Macro
deeps
deeps over 17 years ago
    I am trying to get the power pin co-ordinate details for a given Macro,
        Is there a way by using db commands we can get the exact co-ordinate details of the power pins that are present on the Macro.I am using dbGet command to get the co-ordinate details of the macro location.
thanks
deepak.
  • jgentry
    jgentry over 17 years ago
    Deepak,
      You'll have to go through the macro instance's cell to get the details that you are looking for:
    set instPtr [dbGetInstByName MacroName]
    dbGet $instPtr.cell.pgTerms.pins.allShapes.shapes.rect
    dbGet $instPtr.cell.pgTerms.pins.allShapes.layer.name
       After that, you'll have to code up some translation scripts to put the cell coordinates into inst coordinates.
    JG
  • BobD
    BobD over 17 years ago
    Thanks JG,
    That's the way I'd do it too.  One additional command to be aware of is "dbTransform" that performs the translation you're referring to which converts the cell-level coords to chip-level.
    For example, if you have a cell that's instantated at 0, 884.82 with R270 orientation, you can translate each of the pgTerm rects to chip coordinates like this:
    encounter 26> dbGet selected.pt
    {0 884.82}
    encounter 27> dbGet selected.orient
    R270
    encounter 28>dbGet selected.cell.pgTerms.pins.allShapes.shapes.rect
    {5.355 226.625 34.645 235} {5.355 226.625 34.645 235} {5.355 226.625 34.645 235} {5.355 226.625 34.645 235} {5.355 207.72 34.645 235} {5.355 207.72 34.645 235}
    encounter 29> foreach rect [dbGet selected.cell.pgTerms.pins.allShapes.shapes.rect] {puts "[dbTransform -localPt $rect -inst [dbGet selected]]"}
    {226.625 919.465} {235 890.175}
    {207.72 919.465} {235 890.175}
    Hope this helps,
    Bob
  • jgentry
     Nice!  That will definitely come in handy.  Do you know which version that appeared in?  I have my own translation utilities that I can probably now replace with the dbTranslate command.
    JG
  • BobD
    It's been around since 7.1 I believe.  Here's the usage:
    encounter 1> dbTransform -help
    Usage: dbTransform [-help] [-d] -localPt {{x1 y1} {x2 y2}...} {-inst <instPtr> | {-cell <cellPtr> -orient <orientEnum> -pt {x y}}}
    -help                             # Prints out the command usage
    -d                                # Specifies if points are in dbUnit: default
                                      # is um (bool, optional)
    -inst <instPtr>                   # instance object (db object, optional)
    -cell <cellPtr>                   # cell object (db object, optional)
    -orient {dbcR0|dbcR90|dbcR180|dbcR270|dbcMX|dbcMX90|dbcMY|dbcMY90}
                                      # orientation (enum, optional)
    -pt {x y}                         # location (point, optional)
    -localPt {{x1 y1} {x2 y2}...}     # a pt {x y} or list of pts {{x1 y1} {x2
                                      # y2}...} inside cell (point list, required)
    One other thing to mention: In 9.1, dbTransform will automatically handle lists, so the foreach I used in my example could be removed and dbTrasnform could be called like this:
    [DEV]encounter 1> dbTransform -localPt [dbGet selected.cell.pgTerms.pins.allShapes.shapes.rect] -inst [dbGet selected]
    {226.625 919.465 235 890.175} {226.625 919.465 235 890.175} {226.625 919.465 235 890.175} {226.625 919.465 235 890.175} {207.72 919.465 235 890.175} {207.72 919.465 235 890.175}
  • jgentry
     Very, VERY promising:
    encounter> time {dbTransform -d -localPt $cbox -inst $instPtr}
    104 microseconds per iteration
    encounter> time {eval "agConvertCellCoordsToInstCoords $cellPtr $instPtr $cbox"}
    810 microseconds per iteration
    I may have to do some coordinate rearranging to ensure I always get my data back as llx lly urx ury but that should be quick...
    proc dbTransform_and_legalize {cbox instPtr} {
      foreach {llx lly urx ury} [join [dbTransform -d -localPt $cbox -inst $instPtr]] {break}
      if {$urx < $llx} {
        set tmp $llx
        set llx $urx
        set urx $tmp
      if {$ury < $lly} {
        set tmp $lly
        set lly $ury
        set ury $tmp
      return [list $llx $lly $urx $ury]
    dbTransform
    155 microseconds per iteration
     50% overhead, ouch, still better than my in-house version.  I assume this can be used to convert inst coordinates to cell coordinates as well?  I'll play around with it some more.
    Thanks!
  • jgentry
     Well, can't totally replace my functionality just yet.  dbTransform only supports objects of type 'dbcObjInst'.  My version supports objects of type 'dbcObjInst', 'dbcObjHInst' and 'dbcObjBump'.  Can I put in a request for that?  Also, I couldn't figure out how to go from inst to cell instead of cell to inst.
    JG
  • BobD
    Hi JG,
    I did some asking around and some testing, and I see that dbcObjBump is supported as of 8.1.USR2. I will file an enhancement request for dbcObjHInst support.
    dbTransform currently only supports transforming from the inst level to the cell level and not the other way around. I will file an enhancement request for that as well.  I'll keep you informed on the status as we move along.
    Thanks for your feedback- we appreciate it.
    -Bob
  • jgentry
     Thanks Bob.  I'll keep aneye out for the dbcObjHInst support (any idea the targetted release, I would think this would be fairly simple to implement).
      Regarding the inst-to-cell, cell-to-inst, I ended up creating a pretty generic 'transform-this-to-that' procedure that would take a reference box, reference orient, new box, new orient along with the base coordinates (with respect to the reference box) and do the transform.  Then it doesn't matter what you throw at it (insts, hinsts, bumps, grass, etc.) it simply does the transform asked of it.  When transforming from a cell's coords to an inst's coords, the reference box/orient is {0 0 urx ury}/dbcR0.
    JG
  • PradyK
    PradyK over 15 years ago
    Can I filter the cordinales by pin name?
     Thakns,
    Pradeep
  • BobD
    BobD over 15 years ago
    Sure - you could filter on the pgTerm name and nest it within another dbGet call:
    dbGet [dbGet -p $instPtr.cell.pgTerms.name VDD].pins.allShapes.shapes.rect
