  3. Difference between icecaps tech file and QRC Techgen tech...
  • Replies 12
  • Subscribers 94
  • Views 24511
Difference between icecaps tech file and QRC Techgen tech file
hyeh
hyeh over 17 years ago
Hello there,
I encounter some problems on the tech file as I try to generate the ice (equivalent capacitance) in voltagestorm. Previously, I try to use QRC Techgen to generate the RC tech file. However, this QRC Techgen tech file is not acceptable when I utilize it to generate ice in voltagestorm. I have looked at the manuals and it says that the tech file should be icecaps tech file rather than Techgen tech file.
Does someone have the idea how to generate the icecaps tech file from ict file and its detailed procedure? I missed the important chapter in the voltagestorm data prepare manual.
My voltagestorm is 6.2.2a version and its required icecaps tech file should be the same.
Thanks for any help in advance.
Ho-Hsin
  • Kari
    Kari over 17 years ago
     Can you explain what you mean by "generating ice"? The .tch file you already generated with Techgen should be all you need.
  • hyeh
    Hello Kari
    Thanks for your kind and quick response. I am trying to use Ice & Fire QX to generate the Ice and Fire (Equilvalent Resistance and Capacitance) and Ice & Fire QX requires the tech file.
    Previoulsy, I follow the Techgen procedure and use
    Shell> Techgen -cell
    to generate the tech file successfully. However, when I use this tech file in Ice & Fire QX, this type of tech file is not acceptable. I am wondering if somebody has the experience in using Ice & Fire QX.
    Thanks for your help and patience.
    Best Regards
    Ho-Hsin
  • Kari
     Ah, so you're extracting RCs with QX. Do you have access to QRC? Can you paste the exact warning you're getting? I'm thinking it may be a version issue between the .tch file and QX.
  • hyeh
    Hello Kari,
    The error message is the following when I try to generate the Fire & Ice QX:
    You are using an Icecaps tech file that was generated by an incompatible version of Icecaps.
    You should regenerate the Icecaps tech file using a current version of icecaps
    My Fire&Ice QX and voltagestorm are all 6.2.2a version
    Best Regards
    Ho-Hsin
  • Kari
     If you type "which qx" and "which Techgen", are they coming from the same release directory? Just make sure you use the Techgen that came with the version of QX you're using. But, I believe QRC is what came with 6.2.2. I just looked at a 6.2.1 hierarchy, and QX was not there. QRC is what replaced it.
  • hyeh
    Hello Kari
    I checked my Techgen version which is p7.1.0006 and my QX version and its associated voltagestorm stuff is 6.2.2a.
    Is it the problem? If yes, is there any solution I can fix it.
    Best Regards
    Ho-Hsin
  • Kari
     Like I said, you need to use a version of Techgen that matches your version of QX.
  • hyeh
    Hello Kari,
    Thanks for your quick response.
    Do you mean I have to downgrade the version of Techgen ? If yes, would you mind helping me check which version of Techgen is matching to QX 6.2.2a ? My techgen version now is 7.1.0006.
    Or is there the other way I could fix the problem ?
    Best Regards
    Ho-Hsin
  • Kari
     Yes, you need to use Techgen from your 6.2.2a tool path, if that's where your QX is coming from. At this point, you probably need to talk to whoever maintains the tool installations at your company.
  • hyeh
    Hello Kari
    Thanks for your kind again.
    Actually I have seen the manuals in "Ice&Fire QX Transistor Level Extraction Manual" and the manual mentions that we need
    "A technology file created by IceCaps or provided by Cadence. If you have not yet
    generated a technology file, see Chapter 2, “Interconnect Modeling,” in the Data
    Preparation Manual."
    But when I check the data preparation manual, there is no chapter 2, interconnect modeling.
    Originally, I would like to use IceCaps to generate the tch file. However, I had no information about it because of the missing manuals. Then, you suggested me to use the Techgen.
    Right now, would you mind giving me more details about Icecaps (Read the missing manuals). I am thinking to reuse icecaps to regenerate the icecaps tech file and I am sure the version of Icecaps and QX are compatible, they both are 6.2.2a .
    Thanks for your help again
    Ho-Hsin
