  3. Real DRV and Total DRV
  • Subscribers 94
  • Views 17424
naderi
naderi over 17 years ago
 Hi all,
 Could someone please tell me the difference between "Real DRV" and "Total DRV"?
Also, how the maximum cap and transition can be defined?
Post_route summary showes the following and I wonder how to fix the DRVs.
|     Setup mode     |   all   | reg2reg | in2reg  | reg2out | in2out  | clkgate |
|           WNS (ns):|  0.129  |  0.251  |  0.129  |  1.176  |   N/A   |   N/A   |
|           TNS (ns):|  0.000  |  0.000  |  0.000  |  0.000  |   N/A   |   N/A   |
|    Violating Paths:|    0    |    0    |    0    |    0    |   N/A   |   N/A   |
|          All Paths:|2.48e+05 |1.24e+05 |1.24e+05 |    3    |   N/A   |   N/A   |
Density: 76.000%
Real DRV (fanout, cap, tran): (5072, 0, 0)
Total DRV (fanout, cap, tran): (7556, 49, 125327)
Ali
  • BobD
    BobD over 17 years ago
    Hi Ali,
    I found the following solution via a Sourcelink search for "real drv" that explains the difference between Real and Total DRV:
    http://sourcelink.cadence.com/docs/db/kdb/2005/Dec/11210732.html
    In short, optimization cranks away on things it can fix: data signals (as opposed to clock nets), things that aren't marked FIXED/dont_touch etc.  The Real DRV is reported along withTotal DRV to give you a feel for how good of a job optDesign is doing repairing the things that it is attempting to repair.
    Maximum Cap and Transition can come from 2 sources: The .lib and the SDCs.
    Hope this helps,
    Bob
