  3. Insertion of I/O ports location in First Encounter
  • Subscribers 93
  • Views 4508
archive over 19 years ago
Hi all.
I know there is an option to specify using the GUI the location of the design's input and output ports in First Encounter.
However, this can be a very tedious job to do each time I want to P&R the design after minor changes in the RTL.
Is there a way to import some kind of file with those definitions ? I didn't find such option.
I thought of writing a script that will do the location specifying automatically using First Encounter's command for this option but for some reason, the command doesn't appear in the command log - can you direct me to the proper command for specifying the location of ports?
Help would be very much appreciated,
Adi.
Originally posted in cdnusers.org by adi_j
    if you check out the doc soceUG.pdf under Data Preparation, it talked about how to create the I/O spec file (using Design-> Save->IO) after you edited it the first time in Encounter. You can hand edit it later and re-load it back using "loadIoFile".
    li siang
    Originally posted in cdnusers.org by lisiang
    Hi Adj,
    I use the file "pad.io" to specify my pads or pins. Please see the user guide for the format of this file.
    Sometime, I have to use DEF format (I write a simple awk script to generate the DEF file). I have to use DEF if I have two pins connect to the same net (e.g. a feed-through or to ease top-level routing). It seem that pad.io does not support this. Anyone know how to do this with pad.io? I will reduce some pain for me to craft the DEF. Thanks.
    Eng Han
    Originally posted in cdnusers.org by EngHan
