  3. Follow rails for empty rows.
  • Subscribers 94
  • Views 15511
deeps
deeps over 17 years ago
 I am trying to create the follow rails using encounter.
   but when i use the sroute command, it does not create the follow rails for the empty rows,
   How can i control this??
thanks
deepak.
  • Kari
    Kari over 17 years ago
     Check your sroute command for the option  -corePinNoRouteEmptyRows. You may have this accidentally turned on.
  • deeps
     Hi Kari,
          I have set the corePinNoRouteEmptyRows to "off" but still its not creating follow rails for some empty,(not at all empty rows, follow rails are created at some places where the rows are empty)
             There is no blockage or any kind of obstruction , but still its not able to create  follow rail only in some particular loacation.
                     Do you any idea as what could be the problem.
    thanks
    deepak.
  • Kari
     Deepak,
    I'm not sure what could be going on. Could you try drawing in a followpin by hand in one of these areas and see if  you get any DRC violations? Sometimes it's not obvous why sroute won't draw in a certain area and this can help find out. Also, if you flood your core with filler cells and then route your followpins, does it work then?
    - Kari
