  3. How to set set_dont_touch in Encounter
  • Subscribers 93
  • Views 24207
archive over 19 years ago
How to set dont_touch for a module in Encounter?
Originally posted in cdnusers.org by sundaresan
    Hello Sudersan,
    I have used the below option , but i used the same in SDC .
    How to specify don't_touch instance ??
    STEP-1 :
    # DELAY CELL
    set_dont_touch [get_cells I_cdnuser_cts/S_CKsunderM_DLY_1 ]
    set_dont_touch [get_cells I_cdnuser_cts/S_CKsudarsanM_DLY_2 ]
    How to load this on to Encounter ??
    STEP-2 :
    loadTimingCon -incr ./SDC/dont_touch_cell.sdc
    Hope this will satisfy to query .
    Do let me know if you need further clarifications .
    regards,
    Mohan
    Originally posted in cdnusers.org by mohanch007
    Thanks mohan, its working..........
    archive over 18 years ago
    I have found that this command is only respected for 1 round of optimization commands. It seems, that if I set a group of books as dont_touch, that is honored for the first optimization. If I then route, and do post-opt, the dont_touch dissapears. I have found I need to run the dont_touch command often, and upon each import of the design. Is this normal?
    Originally posted in cdnusers.org by mboudreaux
    dbSetIsNetDontTouch [dbGetNetByName your_net_name_here] 1 dbSetIsInstDontTouch [dbGetInstByName your_hierarchy/your_instance] 1
    Originally posted in cdnusers.org by sreeb
    Did you try adding the dont_touch commands to your constraint file, instead of entering them on the command line?
    Originally posted in cdnusers.org by Kari
    This didn't format very well the first time. To don't touch a net: dbSetIsNetDontTouch [dbGetNetByName your_net_name_here] 1 To don't touch an instance: dbSetIsInstDontTouch [dbGetInstByName your_hierarchy/your_instance] 1 I think you wanted to target a module. Modules are instances but I haven't actually tried don't touching any instances that weren't cells.
