  3. Typical value Missing in the triplets in a generated SDF...
  • Subscribers 95
  • Views 17750
Typical value Missing in the triplets in a generated SDF File
vicky
vicky over 17 years ago
I generated an SDF file using a ETS for single operating condition. In the generated file, the typical timing of the triplet was missing. In the old signalstorm we used to get the same value updtaed in all the triplets but now how come I get only the min and max values.
In the sdf file normal the delay values are updtaed as tripets i.e min:typ:max. In the ETS when I dump the  sdf I see only the min::max values getting upadted. I would like to know the reason
  • vicky
  • Martinage
    Martinage over 17 years ago
     SignalStorm stand-alone delay calculation was capable of performing delay calculation for min,typ, and max at the same time - and provided facilities for controlling what when into the various SDF delay slots.  In ETS (and EDI), nonMMMC mode only supports two delay slots - best and worst under bcWc mode, and early/late under OCV mode - so, simply Typical delays never get calculated.  We have chosen to keep the Typ SDF slot empty rather than populate it - by replicated either the min or max slot, or averaging them.    This way, there is no confusion with how the Typ value was calculated (or not) by someone using the SDF.
     In MMMC mode, the system will calculate delays for as many corners as you want.  The write_sdf  command has the functionality to allow the user to specify which data gets used to populate each of the SDF min:typ:max slots.
    Ed
  • vicky
    vicky over 16 years ago
     Will this not be an issue for simulation tools which would normally read the TYP values.
