  3. Die-size resizing(using resize line) using encounter 8.1...
  • Subscribers 92
  • Views 1060
Die-size resizing(using resize line) using encounter 8.1 has some problem...
NAADHAN
NAADHAN over 16 years ago
Hi ,
          In our current project we need to resize the die for various reasons. Initially when we tried to do that using 8.1 Version... we could observe that the origin is changing from (0,0) to some other value....
But this problem doesnt exist in Version 7.1USR2...... Does any one know what could be the reason for the same ????
Thanks & Regards,
Naadhan
  • Kari
    Kari over 16 years ago
     Hi Naadhan,
     What specific resize commands are you using?
    - Kari
  • NAADHAN
    Hi Kari... i normally use the ENC GUI ...and use the Resize FloorPlan option in the FloorPlan Menu.... there i use shift Based method...Inside which i give the co-ordinattes for resize line.
  • Kari
     I wasn't able to reproduce this problem in 8.1 USR2, so it may be something specific about your design. Can you file a service request on Sourcelink?
