  3. How to add buffers to all inputs and spare cells
  • Subscribers 93
  • Views 20087
archive over 19 years ago
1) i need to add buffers and antenna diodes to to all the inputs after completeing the routing,
how to do it?
2) Also i have to add some 20 buffers 20 inverters and 10 nand gates(with thier inputs connected to VSS)  to my design after Routing, how to add these spare cells?
i tried to add spare cells with the Add spare cells option available in encounter but i am not able to insert exactly 20buffers?
Kindly help me to do it
Originally posted in cdnusers.org by sundaresan
    1) is your design a block or chip ??
    i) does your design shows any process antenna violations ??
    2) does your ECO net-list has any such changes ??
    Do you know the net name & buffer , inverters, nand type ??
    Once final Q. are you undergoing any training classes or the above talk was your challenge ??
    Please let me know !!
    Mohan
    Originally posted in cdnusers.org by mohanch007
    I am not undergoing any training, but i am new to encounter tool And working on a Block level design using it without any external support.
    And these are issues which i dont get proper help from the Cadence documents. thats why i post my questions here
    1. Though i dont have any antenna violation, But still i have to insert diodes and buffers at the input pins for the block.
    2. i need to insert these spare cells for latter usage. these cells are not part of of the Design netlist. It is just for future usage.
    Hi Sundaresan,
    From my understanding of your need, the antenna diode, buffer should be added before placement, and after floorplan. See "attachIOBuffer" command.
    For spare cell, I usually add it into the netlist. Then use the command "specifySpareGate" to evenly place it in the core. Run the command before placement.
    Eng Han
    Originally posted in cdnusers.org by EngHan
