  3. Widening witdh of wire at Macro Pin using encounter
  • Subscribers 91
  • Views 13633
KVBABU
KVBABU over 16 years ago
 Hi all,
In my design , i have some macro's , whose pin width is more than the default width of routing. So, i wanted the nanorouter to route this using default width  and while making a hook-up to macro pin , the width has to made equal to width of pin.
It is possible to achive this using nanorouter. if so please provide   command or GUI option.
K.Viswanadh Babu
  • Kari
    Kari over 16 years ago
     I don't know of an automated way to do this, but I'm curious why it's even necessary. If you really need to do it, the "hard" way is to hand route out from these pins a little bit (which would make them SPECIALNETS since you're forcing a NONDEFAULT width), then let Nano take it from there.
