  3. About encounter DB command & its hidden option?
  • Subscribers 93
  • Views 8933
archive over 19 years ago
Dear All:
I am a new comer here, I got two questions to ask:
1. Is there any db commands that can manipulate polygons, which means that I can cut a rectangular region or fence into polygon shaped?
2. Can anyone tell me some encounter hidden variables like "set drouteUseMinSpacingForBlockage true"
Originally posted in cdnusers.org by eminemshow
    Hello eminem,
    Welcome to the forum! Hope you find it useful.
    For item 1, you could use the "setObjFPlanBoxList" command to define a polygon shape for a fence. You can see this command echoed to your .cmd file if you define an object to have more than 4 sides with the "Cut Rectilinear" widget in the GUI. Here is some sample output:
    setObjFPlanBoxList Module {DTMF_INST/RESULTS_CONV_INST} 922.0200 673.6800 1151.7000 840.0000 922.0200 840.0000 1042.1400 905.5200
    For additional information, type:
    encounter> help setObjFPlanBoxList
    or
    encounter> man setObjFPlanBoxList
    Regarding hidden variables- maybe you could provide some additional information on what you're trying to achieve that isn't happening by default?
    Hope this helps,
    Bob
    Originally posted in cdnusers.org by BobD
    1. Really thanks, BobD!!! :-) But I really found that when I want to get the module constraint (such as region, guide , fence, etc) boudary box, if the really boundary is a L shaped (or any other polygon shaped) box, I use the 'dbConstraintBox' command, I get the rectangular box, not a polygon.......sigh! Is there a command through which I can get polygons!?
    2. For the hidden variables, when I use the 'ecoChangeCell' command, encounter just run 'refinePlace' everytime it finishes a 'ecoChangeCell' command ,is there a variable to control this. By which I can just run 'refinePlace' once after all 'ecoChangeCell' commands?
    For 1, there's a couple of different ways to get this. First, there's a corresponding "getObjFPlanBoxList" that goes with setObjFPlanBoxList. It works like this:
    encounter 34> getObjFPlanBoxList Module DTMF_INST/RESULTS_CONV_INST
    942.48 598.08 1172.16 749.28 942.48 749.28 1100.88 829.92
    You could also query the db similarly to how you have with "dbConstraintBox" to get a list of the boxes that make up the polygon. Here's an example of how you could do that with FE-TCL:
    proc userConstraintBoxList {hinstName} {
    set constraintBoxList {}
    set constraint [dbHInstConstraint [dbGetHInstByName $hinstName]]
    set constraintBox [dbConstraintBox $constraint]
    dbForEachConstraintBox $constraint box {
    set ptrBox [dbBoxPtrBox $box]
    lappend constraintBoxList $ptrBox
    if {[llength $constraintBoxList] > 0} {
    return $constraintBoxList
    } else {
    encounter 28> userConstraintBoxList DTMF_INST/RESULTS_CONV_INST
    {1884960 1498560 2201760 1659840} {1884960 1196160 2344320 1498560}
    This scripted method is probably easier to do if you're writing a script because you can control the formatting of what is returned to suit your needs.
    For item 2, using 6.2 you can use "setECOMode -noRefinePlace" to suppress refinePlace during eco commands. In 6.1 and earlier, you can use "setOptMode -noRPlace" to achieve same.
    -Bob
    Really thanks!! BObD, hope we can be friends!! My MSN is eminem198123@hotmail.com
