  3. problem about Trig. skew rise/fall skew
  • Subscribers 94
  • Views 1907
icmaple
icmaple over 17 years ago
after CTS,
Trig. Edge Skew                : 437.7(ps)              150(ps)
Rise Skew                      : 561.6(ps)
Fall Skew                      : 1129.8(ps)
which skew need us care ?
  • Kari
    Kari over 17 years ago
     In the "Synthesizing Clock Trees" chapter of the User Guide, there is a section called "How CTS Calculates Skew Values" which explains this. The triggered edge skew is probably the one you want to look at.
  • icmaple
    Kari 您好! after CTS, if falling skew is larger than trig.skew, can i only care trig. skew and ignore falling skew? ++++++++ 2009-09-23 04:35:48 <>在来信中写道:+++++++++++++++++++++++++++++++ > > >In the "Synthesizing Clock Trees" chapter of the User Guide, there is a section called "How CTS Calculates Skew Values" which explains this. The >
  • Kari
     It may depend on what you're looking at the skew for. As long as we're meeting timing, we don't worry too much about the skew itself. In fact, we often make use of "useful skew", where the clock is intentionally skewed more than the target in order to meet some timing paths. Of course you still need some sort of skew target to build a good tree to start with, but the skew number in and of itself may not be that important. Are you having timing issues that you think are related to the clock skew?
