  3. problem about Encounter Library Characterizer(ELC)
  • Subscribers 95
  • Views 1157
Nathen
Nathen over 17 years ago
I use a file named "setup.ss" for Encounter Libarary Characterizer, but it displays : [error (dg_gsim)] cannot find the setup file information, ensure that the name of the setup file is specified with the SETUP directive in the elccfg configuration file.
What's the meaning of this? Could anyone give me an example for the name of setup file?
  • mbhealy
    mbhealy over 17 years ago
     You need to specify the setup file in the elccfg file. It should be in the working directory when you start up elc. Also, you should include the line SETUP="setup.ss" in that file. You should look into the user guide. It explains what the format of the elccfg file is.
