  3. Problem in using v2lvs to convert verilog netlist into spice...
  • Subscribers 93
  • Views 20202
Problem in using v2lvs to convert verilog netlist into spice netlist
huybforever
huybforever over 16 years ago
I use the command:
v2lvs -v lp5_16b.nl.v -o lp5_16.tlnl.sp
But the generated netlist can not be simulated in HSPICE since it has syntax like "$PINS" in the netlist.
I heard that if you want the spice netlist can be simulated using HSPICE, you have to add the "-i" option. So I use:
v2lvs -v lp5_16b.nl.v -o lp5_16.tlnl.sp -i
But it reports error:
Error: no module declaration for module HS65_LS_NAND2AX14 first encountered in module lp5_16b_DW01_add_70
       (-i switch requres Verilog declarations for all modules.)
Who can tell me how to solve this problem?
Should I add the "-l" or "-s" option?
 Thanks a lot!
  • BobD
    BobD over 16 years ago
    Could you let us know which Cadence tool v2lvs is from so I can track down someone to field your question?
    Bob
  • rh0dium
    rh0dium over 16 years ago
    huybforever,
    First off v2lvs is a product from Mentor. "The V2LVS (Verilog-to-LVS) converter translates a Verilog structural netlist into a LVS SPICE netlist suitable for Calibre nmLVS/nmLVS-H comparison against a layout." Furthermore it does not make it an HSPICE (From Synopsys) simulatable compatible netlist. Specifically the "-i" option you specifies that calls to subcircuits with pins be done in order, according to traditional SPICE rather than with $PINS construct. Make no question about it - what you are trying to do is not going to work. Since you are on a Cadence page why don't you just do a verilog-in then a spice-out.
    HTH.
    Steve
