  3. question about Encounter Library Characterizer
  • Subscribers 96
  • Views 15000
Nathen
Nathen over 17 years ago
I meet a problem when proccing simulating, this is the part of displays I copy from ELC.
AND2X1         typical       D0000     SIMULATE     FAIL        stdcell09
AND2X1         typical       D0001     VERIFICATE   PASS        stdcell09
AND2X1         typical       D0002     SIMULATE     FAIL        stdcell09
AND2X1         typical       D0003     VERIFICATE   PASS        stdcell09
AND2X1         typical       D0004     SIMULATE     FAIL        stdcell09
AND2X1         typical       D0005     VERIFICATE   PASS        stdcell09
AND2X1         typical       D0006     SIMULATE     FAIL        stdcell09
AND2X1         typical       D0007     VERIFICATE   PASS        stdcell09
NAND2X1        typical       D0000     SIMULATE     FAIL        stdcell09
NAND2X1        typical       D0001     VERIFICATE   PASS        stdcell09
NAND2X1        typical       D0002     SIMULATE     FAIL        stdcell09
NAND2X1        typical       D0003     VERIFICATE   PASS        stdcell09
NAND2X1        typical       D0004     SIMULATE     FAIL        stdcell09
NAND2X1        typical       D0005     VERIFICATE   PASS        stdcell09
NAND2X1        typical       D0006     SIMULATE     FAIL        stdcell09
NAND2X1        typical       D0007     VERIFICATE   PASS        stdcell09
[INFO(db_spice)] Check the encounterlc.log/<ipdb_name>/<DESIGN>_<PROCESS>_<ID>.log file to determine the cause of the failure. The SPICE simulation log file can be found in the /home/nliu7071/signalstorm/ss/encounterlc.work/<DESIGN>_<PROCESS>_<ID>/ directory.
 - Total Simulation : 182
 - Total Passed     : 66(36.26%)
 - Total Failed     : 116(63.74%)
I check the log file and it says that :
Error found by spectre during circuit read-in.
    "typical_D0000_tr.sp" 45: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 46: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 47: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 48: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 49: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 50: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 51: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 52: Unknown dot word `.measure'.
    "typical_D0000_tr.sp" 53: Unknown dot word `.measure'.
What 's the reason of these errors? If there is anyone who faces the same problem before?
  • lisiang
    lisiang over 17 years ago
    did you use Hspice or Spectre as the simulator?
     li siang
  • SindyZeng
    SindyZeng over 16 years ago
    i have got the same message with Nathen when proccing simulating . and i use hspice for simulate.
    how can i solve this problem ?
