  3. Declaring analog power
  • Subscribers 93
  • Views 14589
KVBABU
KVBABU over 17 years ago
 Hi All,
After synthesis,I want to  declare digital power nets in the verilog netlist as supply0 & supply1. and its good and working fine.
But, i want to declare analog powernets also. Could you suggest any other syntax for this. Because, if use the same syntax, i suppose the tool can not differentiate them.
so is there any alternative
KVB
  • BobD
    BobD over 17 years ago
    Could you clarify which Cadence tool is this related to?
    Bob
