  3. help! why my encounter always crash out?
  • Subscribers 95
  • Views 15312
icmaple
icmaple over 17 years ago
my machine configure: Mem:  32908824k total, 20792292k used, 12116532k free,    78372k buffers
Swap:  8385920k total,        0k used,  8385920k free, 16006416k cached
when i optdesign , encounter crash out:   report below :
*optDesign ... cpu = 1:01:13, real = 1:01:17, mem = 3370.9M **
*** Starting trialRoute (mem=3370.9M) ***
There are 0 pin guide points passed to trialRoute.
Options:  -maxRouteLayer 5 -handlePreroute -keepMarkedOptRoutes -noPinGuide
Nr of prerouted/Fixed nets = 0
routingBox: (0 0) (16000000 14000000)
coreBox:    (28000 28000) (15972000 13972000)
**ERROR: (SOCSYUTIL-15):        Cannot malloc type "sysBigMacByte" size=227752272 bytes.
Probably ran out of virtual memory.
*** Memory Usage v0.144.6.3 (Current mem = 3462.359M, initial mem = 62.133M) ***
--- Ending "First Encounter" (totcpu=1:03:14, real=1:42:04, mem=3462.4M) ---
  • BobD
    BobD over 17 years ago
    Are you running in 32-bit mode by chance?  The memory levels make me wonder if you might be hitting the 32-bit limit on the system.
    Could you try "encounter -64" to see if that resolves the problem?  If so, you could set this UNIX environment variable in your .cshrc file to have the tool automatically start in 64-bit mode when running on a 64-bit machine:
    setenv CDS_AUTO_64BIT ALL
    Bob
  • jabbar
    jabbar over 13 years ago
     Thank you very much Bob for the reply. I faced the same problem for many weeks and finally had solved it with your suggestion.
     Thanks again.
