  3. ELC simulation fails but without any error message
  • Subscribers 94
  • Views 14606
Nathen
Nathen over 17 years ago
 I run simulation using Encounter Library Characterizer. It displays "simulation failed" but I check log in encounterlc.work, it says no error,no warning, no notice. And I can not find any other error message anywhere.Does anyone meet the same problem before? How to solve it. Please help.
    archive over 17 years ago
    Hi Nathen,
    Did you also check the encounterlc.log directory?  The failure could be due to mismatches between the simulation result and expected logic value.  This can happen if the input slew and/or output load are too large and the cell output does not complete full transition.  Also ELC might not have recognize the logic of a complicated cell properly.
    Wilson
