  3. ELC doesn't simulate anything
  • Subscribers 94
  • Views 1323
mbhealy
mbhealy over 16 years ago
 Hi All,
I'm having a problem getting elc to run any simulations. I'm currently testing on two small inverters.
 Whenever I run db_spice I get the following message:
 [WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error
I can't find any errors in my configuration files. Would someone please look at them and tell me if they see anything wrong?
Here is my elccfg:
 #Specify the environment variable settings.
EC_SIM_USE_LSF=1;
EC_SIM_LSF_CMD=" ";
EC_SIM_LSF_PARALLEL=2;
EC_SIM_TYPE="hspice";
EC_SIM_NAME="hspice";
EC_SPICE_SIMPLIFY=1;
EC_CHAR="ECSM-TIMING ECSM-POWER";
#Specify the characterization inputs.
SUBCKT="my_cells.sp";
MODEL="my_typical_models.sp";
DESIGNS="INVX1 INVX2";
SETUP="my_setup.ss";
PROCESS="typical";
And here is my_setup.ss:
 Process my_typical_process {
        voltage = 1.5;
        temp = 25;
        Corner = "typical";
        Vtn = 0.320;
        Vtp = 0.316;
Group POWR{
        PIN = VDD;
Index inv_index {
        Slew = 0.028n 0.044n 0.076n 0.138n 0.264n 0.516n 1.02n ;
        Load = 0.00079p 0.002054p 0.00474p 0.010112p 0.020856p 0.042186p 0.08532p ;
Signal std_cell_sig {
        unit = REL;
        Vh=1.0 1.0;
        Vl=0.0 0.0;
        Vth=0.5 0.5;
        Vsh=0.8 0.8;
        Vsl=0.2 0.2;
        tsmax=2.0n;
Signal power_sig {
        unit = ABS;
        Vh=1.5 1.5;
        Vl=0.0 0.0;
        Vth=0.75 0.75;
        Vsh=2.0 2.0;
        Vsl=0.5 0.5;
        tsmax=2.0n;
 Margin m0 {
        setup   = 1.0 0.0 ;
        hold    = 1.0 0.0 ;
        release = 1.0 0.0 ;
        removal = 1.0 0.0 ;
        recovery = 1.0 0.0 ;
        width   = 1.0 0.0 ;
        delay   = 1.0 0.0 ;
        power   = 1.0 0.0 ;
        cap     = 1.0 0.0 ;
Nominal n0 {
        delay = 0.5 0.5 ;
        power = 0.5 0.5 ;
        cap   = 0.5 0.5 ;
Simulation std_cell_sim {
        transient = 0.01 80n 10p;
//      dc = 0.1 4.5 0.1;
        bisec = 6.0n 6.0n 100p;
        resistance = 10MEG;
set process(my_typical_process) {
        simulation = std_cell_sim;
        index = inv_index;
        signal = std_cell_sig;
        margin = m0;
        nominal = n0;
set signal(my_typical_process) {
        Group(POWR) = power_sig;
Thanks!
  • mbhealy
    I figured out that the problem was with my subcircuit definitions. ELC seems to be abstracting away all my ports for some reason. This seems to be related to the fact that Calibre has extracted each net of the circuit into it's own subcircuit definition and then connected the transistors and coupling capacitances to these net-modeling subcircuits.
  • cdbular
    cdbular over 15 years ago
    Hi, I have exactly the same problem.
    How did you specifically solve the problem?
    Here is my  elccfg file
    #Specify the environment variable settings to use for characterization.
    EC_SIM_USE_LSF=1;
    EC_SIM_LSF_CMD="";
    EC_SIM_LSF_PARALLEL=10;
    EC_SIM_TYPE="spectre";
    EC_IGN_XTG=1;
    EC_SIM_NAME="spectre";
    EC_CHAR=“ECSM-TIMING ECSM-POWER”;
    set_var EC_SPICE_SUPPLY1_NAMES = "vdd vdd2";
    set_var EC_SPICE_SUPPLY0_NAMES = "gnd gnd2";
    set_var EC_HALF_WIDTH_HOLD_FLAG = true;
    SUBCKT="osu05_stdcells.sp";
    MODEL="ami05.m";
    DESIGNS="INVX1";
    SETUP="setup.default";
    PROCESS = "elc_process";
    And here my setup file
    Process typical{
        voltage = 5.0;
        temp = 25;
        Corner = "";
        Vtn = 0.65;
        Vtp = 0.95;
    Signal std_cell {
        unit = REL;
        Vh=1.0 1.0;
        Vl=0.0 0.0;
        Vth=0.5 0.5;
        Vsh=0.8 0.8;
        Vsl=0.2 0.2;
        tsmax=2.0n;
    Signal VDD5.0V {
        unit = ABS;
        Vh=5.0 5.0;
        Vl=0.0 0.0;
        Vth=2.5 2.5;
        Vsh=2.0 2.0;
        Vsl=0.5 0.5;
        tsmax=2.0n;
    Simulation std_cell{
        transient = 0.1n 80n 10p;
        dc = 0.1 4.5 0.1;
        resistance = 10MEG;
    Index X1{
        Slew = 0.100n 0.30n 0.7n 1.0n 2.0n;
        Load = 0.025p 0.05p 0.1p 0.3p 0.6p;
    Index X2{
        Load = 0.050p 0.10p 0.2p 0.6p 1.2p;
    Index X4{
        Load = 0.1p 0.2p 0.4p 1.2p 2.4p;
    Index X8{
        Load = 0.2p 0.4p 0.8p 2.4p 4.8p;
    Index Clk_Slew{
        bslew = 0.100n 0.5n 1.0n;
    Index IO5x5{
        Slew = 0.1n 0.3n 0.6n 1.3n 3.0n;
        Load = 5p 10p 20p 50p 75p;
    Group POWR{
        PIN = *.Vdd *.Vdd2;
    Group Core_Pins{
        PIN = *.DO *.DI ;
    Group Pad_Pins{
        PIN = *.YPAD ;
    Group X1{
        CELL = *X1 ;
    Group X2{
        CELL = *X2 ;
    Group X4{
        CELL = *X4 ;
    Group X8{
        CELL = *X8 ;
    Group Clk_Slew{
        PIN = *.CLK ;
    Margin m0 {
        setup     = 1.0 0.0 ;
        hold     = 1.0 0.0 ;
        release = 1.0 0.0 ;
        removal = 1.0 0.0 ;
        width    = 1.0 0.0 ;
        delay     = 1.0 0.0 ;
        power     = 1.0 0.0 ;
        cap     = 1.0 0.0 ;
    Nominal n0 {
        delay = 0.5 0.5 ;
        power = 0.5 0.5 ;
        cap   = 0.5 0.5 ;
    set process(typical){
        simulation = std_cell;
        signal = std_cell;
        margin = m0;
        nominal = n0;
    set index(typical){
        Group(X1) = X1;
        Group(X2) = X2;
        Group(X4) = X4;
        Group(X8) = X8;
        Group(Pad_Pins)  = IO5x5;
        Group(Core_Pins) = X4;
        Group(Clk_Slew)  = Clk_Slew;
    set signal(typical){
        Group(POWR) = VDD5.0V;
  • affaq
    affaq over 15 years ago
    I need to look at your spice netlist file to see whether something wrong there or not.
    Affaq
