  3. about mechanism of CTS ??
  • Subscribers 94
  • Views 14843
icmaple
icmaple over 17 years ago
After cts tracing the clock path,  cts will divide many steps to do local cts (then use macro model to do cts upper level) from Sinks up to source clock as below for example:
**** CK_START: Update Database (mem=3265.2M)
36 Clock Buffers/Inverters inserted.
**** CK_END: Update Database (cpu=0:00:00.0, real=0:00:00.0, mem=3265.2M)
**** CK_START: Macro Models Generation (mem=3364.6M)
*  sink: max rise/fall tran=[276,286], (bnd=200ps)
*buffer: max rise/fall tran=[651,494], (bnd=500ps)
**** CK_END: Macro Models Generation (cpu=0:00:10.7, real=0:00:11.0, mem=3370.6M)
SubTree No: 329
Input_Pin:  (u_center_ctrl/u_clk_sys_buf1/A)
Output_Pin: (u_center_ctrl/u_clk_sys_buf1/Y)
Output_Net: (u_center_ctrl/sys_clk_buf1) DontTouch
**** CK_END: Macro Models Generation (cpu=0:00:10.8, real=0:00:11.0, mem=3370.6M)
SubTree No: 330
Input_Pin:  (u_center_ctrl/u_and_3/B)
Output_Pin: (u_center_ctrl/u_and_3/Y)
Output_Net: (u_center_ctrl/sys_clk_pwr) DontTouch
SubTree No: 331
Input_Pin:  (NULL)
Output_Pin: (sys_clk)
Output_Net: (sys_clk) DontTouch
can someon interpret the mechanism of cts in detail ?  thanks
  • BobD
    BobD over 17 years ago
    I think the best way to get a feel for the structure of the clock tree that's been built is by going to Clock->Clock Tree Analyst.  It provides a rich set of features that allow you to visualize the clock network structure on a time axis and debug all sorts of situations that commonly occur on clock trees.  More information on this capability is available here:
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/encounter/encounter8.1.3/clockG.html#1108188
