  3. Stacked via violations in encounter power router.
  • Subscribers 96
  • Views 19911
deeps
deeps over 17 years ago
 I am trying to create the power routes using Encounter 9.1
There are lot of memories in the design which has power pins in layer M4  ( design is 8 Metal layer process) i create the stripe in M3 & M7 where in M7 gets tapped to some of the power pins of the memories as the pitch of M7 is such that some of the memory pins does not get over lapped with M7 stripe so those are left open. so i create a sub mesh kind of struture on those memory pins & connect the sub mesh to the stripe in M7
   During this stage there are lot of Stacked Via Violations are created,
       Can i use any switchs or any settings so that the tool understands the requriment & create the stack vias properlly.
thanks
deepak.
  • Kari
    Kari over 17 years ago
    It's hard to say without knowing the specific via stacking rules for your process. Usually, power vias do not trigger via stack violations because the metal is wider and via arrays are used, instead of a single via. Most via stack rules only apply to single vias - arrays do not trigger the violation. Are your power stripes thin enough that you only have one via cut at the intersections? There are some different via stacking keywords available in the LEF file that may help you, but I'm not sure what your paricular violation is. What is flagging the violations? VerifyGeometry, or your signoff DRC tool?
  • deeps
    Hi Kari,
    I am using verify geometry command to get details of the violations (not Sign off)
     I am not sure the reason for this kind of violations, I got some inputs from Cadence support saying that I need to set some variable before creating the power routes (setvar ALLOWOVERLAPINSTACKVIA true)
    But still there are lot of stacked via violations
    Here the violations are created even with via array,  I am not sure how to get rid of this kind of violations.
    Deepak.,
  • Kari
    Hi Deepak,
    Can you paste the exact wording of the verifyGeometry violation along with a picture of the violation?
    - Kari
  • noorcadence
    noorcadence over 14 years ago
    Hi Kari,
    I am also seeing below issue ,
     Regular Via of Net design1/mlm_ahb_main_i/FE_OFN86065_sram_main_wdata_298_ & Regular Via of Net design1/mlm_ahb_main_i/FE_OFN86065_sram_main_wdata_298_
    |( VIA5 VIA1 )
    bbox = (2312.905, 1807.365) (2312.975, 1807.435)
    mnm
  • Kari
    Kari over 14 years ago
     What kind of violation is this? Short? Spacing? A picture would help...
     - Kari
  • snoredpig
    snoredpig over 14 years ago
    zoom the region and use editPowerVia to delete those vias. and re-generate those vias by editPowerVia by specified area.
