  3. About the OVERLAP layer in LEF, how can I get its boxes...
  • Subscribers 93
  • Views 19010
About the OVERLAP layer in LEF, how can I get its boxes in FE
archive over 19 years ago
Dear ALL:
As you know, the OVERLAP layer in LEF is for defining rectlinear blocks, now I want list all the physical box for this layer, what command or TCL scriptss can I use, pls help me!
Many thx!!
Originally posted in cdnusers.org by eminemshow
    Could you please detail your question:
    Are you dealing with a hierarchical design ?
    Your overlap Layer represent rectilinear partition ?
    To print the cutout rectangle for a partition (before commit) you can try the following script:
    set instancePtnName "You partition instance name"
    set ptnCut [dbGetPtnCutByName $instancePtnName]
    while {$ptnCut != "0x0"} {
    if {[dbPtnCutName $ptnCut] == $instancePtnName} {
    set ptnCutBox [dbPtnCutBox $ptnCut]
    puts $ptnCutBox
    set ptnCut [dbPtnCutNextInFPlan $ptnCut]
    Originally posted in cdnusers.org by bougantp
    Dear bougantp:
    Thanks!! My design is not hierarchical design. You code is to get all the partition cuts of a design, it is useful for a self-defined rectilinear shape block. But my scenario is that I have a HARD macro imported from a LEF file. I want to get OVERLAP layer box which is similar to a partition cut layer box.
    Hi eminemshow,
    In $ENCOUNTER/tools/fe/gift/scripts/tcl, there is a script called "user_scripts.tcl" that contains a proc called "userGetInstOverlap" that I believe does what you're seeking to do. Could you have a look at that and report back whether it does what you need?
    Bob
    Originally posted in cdnusers.org by BobD
    Dear BobD:
    I cannot find the script 'user_scripts.tcl' under the specified path. I can find a lot of other tcls except this one......My SOCE is SOC52USR2. Can you upload the script.
    Many thanks!!
    Really thanks, BodD!!
    I find the tcl in the SOC61 update tar file. It is what I want. We just cannot get the OVERLAP layer at the top cell level, but at the hierarchical inst level. The script is amazing!!
    Best Regard!!
