  3. BUffer Profiling
  • Subscribers 93
  • Views 18568
BUffer Profiling
archive over 19 years ago
Is there a way to get the buffer classiifcation in encounter i.e a way to report the number of CTS buffers, hold buffers etc .
Originally posted in cdnusers.org by mvvijay78
    In the Encounter User Guide doc, you can find the naming convention used by Encounter during implementation to added cells and nets.
    In Optimizing Timing -> Naming Conventions
    Typically you can find that buffer added for fix Hold will be prefix with "FE_PHC".
    You can use this prefix analysis to sort all your buffers.
    Originally posted in cdnusers.org by bougantp
    Really learn a lot of things from you, bougantp!! Solute!!
    Originally posted in cdnusers.org by eminemshow
    Hi please make a note to get number of CTS buffers :
    easy way : in "Clock Tree Timing Report" you will get Nr. of Buffer : ** " value directly but need to take from all CTS root point.
    alternative way for design : grep "__L" in def file .
    Note :
    NameDelimiter
    if you change in any case by
    NameDelimiter # creates names with the format clk##L3#I2, rather than the default format, clk__L3_I2.
    UseSingleDelim YES
    (creates clock and net names with the format clk_L3_I2, rather than the default format, clk__L3_I2)
    Naming Conventions
    Instance Description Command
    FE_ABC Instance name added by multi-driver netbuffering.optDesign
    FE_ABN Net name added by multi-driver net buffering. optDesign
    FE_OCPN Net name added by critical path optimization. optDesign
    FE_OCPC Instance name added by critical path optimization.optDesign
    FE_FHN Net name added by hold time repair optDesign
    FE_FHC Instance name added by hold time repair. optDesign
    FE_RC Instance created by netlist restructuring. optDesign
    FE_RN Net created by netlist restructuring. optDesign
    FE_OFN Buffer net name added by rule-based buffer insertion insertRepeater/optFanout
    FE_OFC Buffer instance name added by rule-basedbuffer insertion insertRepeater/optFanout
    FE_PHC Cell name added by post-route hold repair. optDesign
    FE_PHN Net name added by post-route hold repair. optDesign
    FE_PSC Cell name added by post-route setup repair. optDesign
    FE_PSN Net name added by post-route setup repair. optDesign
    FE_ECON A net added by interactive ECO
    FE_ECOC An instance added by interactive ECO
    Mohan
    Originally posted in cdnusers.org by mohanch007
