  3. TCL
  • Subscribers 95
  • Views 17382
TCL
Brian Harrison
Brian Harrison over 16 years ago
Is there a proper way to load a dynamically loadable TCL extension in encounter?
example:  www.swig.org/tutorial.html
When I complile the above example and try to load it within encounter I get:
couldn't load file "./example.so": ./example.so: cannot open shared object file: No such file or directory
This works fine within a normal tcl shell.
On a previous project I wrote crude placement algorithm in TCL using encounter commands.  This was done to overcome limitations with encounter clock tree synthesis with IBM ASIC methodology.   The algorithm worked great, but was slow since being in TCL.   I could speed this up in C/C++ using SWIG to create the TCL wrapper.
Any help?
Best Regards,
Brian
  • jgentry
    jgentry over 16 years ago
     The "No such file or directory" seems suspect but it's weird that it works in stock Tcl.  I usually load all of my tcl packages (albeit, all have been straight Tcl) using packages.  Perhaps there's something wrong with your auto_path?  Are you loading these directly (using 'load') or via 'package require'?
    JG
  • Brian Harrison
    Thanks JG,
    I'm using the 'load' to load the binary extension.
    The tcl interpreter can be compiled to not to allow dynamic loading,  'load', so maybe that's the problem.
    I tried adding a directory:   set auto_path [linsert $auto_path 0 /home/bharris/dev/swig]
    but no luck.
    info library gives me:
    /apps/SOC81/08.10.002/share/tcltools/icd8.4.11/lib/tcl8.4
    Is there a way to add a path to it?
    Best Regrads,
    Brian
  • jgentry
    Sorry, I'm out of ideas.  We'll probably need Cadence to track this one down.  Let me know what you find out.
    JG
  • BobD
    BobD over 16 years ago
    I don't have experience in this area either.  Checking around Cadence for help. Stand by...
  • BobD
    I summoned help from our TCL blackbelts internally and I *think* I stumbled onto the same problem as you.  I built example.so on 32-bit and then ran on 64-bit Encounter and got this error message:
    UNIX> encounter
    encounter 1> load example.so
    couldn't load file "example.so": example.so: cannot open shared object file: No such file or directory
    In my case, I have Encounter automatically run in 64-bit mode when I'm on a 64-bit machine with this env var (consequently I don't think about whether I'm running 32-bit or 64-bit):
    setenv CDS_AUTO_64BIT ALL
    If I force 32-bit:
    UNIX> encounter -32
    encounter 1> getBuildArch
    32bit
    encounter 2> load example.so
    ->Works no problem
    Looks like the key is to make sure you're running Encounter on the same platform and architecture as you compiled.
    When you chance to have a look, please let us know whether this resolved your issue.  If it does not, we have the right people lined up to help out.
    Thanks!
    Bob
  • Brian Harrison
    Excellent!  Thanks Bob and your TCL blackbelts. When using the example on how to create a TCL extension from:  http://www.swig.org/tutorial.html
    add -m64 to the gcc command so it will load in encounter 64bit:
    unix % gcc -fpic -c -m64 example.c example_wrap.c -I/usr/local/include
    unix % gcc -shared -m64 example.o example_wrap.o -o example.so
    Best Regards,
    Brian
