  3. HELP for WARN: (SOCDB-2078)
  • Subscribers 94
  • Views 14757
JZ Huo
JZ Huo over 16 years ago
      In the cusomter design,  some output port/pin are assigned to 1`b0 or  1`b1 .  So Encounter use tieLo/tieHi cell for them.   However,  Encounter gives the WARN: SOCDB-2078.
**WARN: (SOCDB-2078):   Output pin ZN of instance cortexr4_innowrapper_TIEHILO_LTIELO_15 is connected
to ground net ARPROTM[1].  This can create a short circuit if the output is 1.  Check the connectivity
 in the netlist.
**WARN: (SOCDB-2078):   Output pin Z of instance cortexr4_innowrapper_TIEHILO_LTIEHI_2 is connected to
 power net RREADYM.  This can create a short circuit if the output is 0.  Check the connectivity in th
e netlist.
**WARN: (SOCDB-2078):   Output pin ZN of instance cortexr4_innowrapper_TIEHILO_LTIELO_16 is connected
to ground net BRESPS[0].  This can create a short circuit if the output is 1.  Check the connectivity
in the netlist.
The ARPROTM[1] RREADYM BRESPS [0] are the output pins which are assigned to 1`b0 or 1`b1 in Netlist  .
The question is it seems  Encounter does NOT route these nets, so we get LVS fail in PVS.
Labeled Schematic Pin     | Matched Layout Pin     | Matched Layout Net
AWIDM[3]                  | <Missing>              | X31/5782
AWIDM[2]                  | <Missing>              | X31/5783
AWIDM[1]                  | <Missing>              | X31/5784
AWLENM[3] .  .  .  .  .  .| <Missing> .  .  .  .  .| X31/5785
AWSIZEM[2]                | <Missing>              | X31/5787
AWBURSTM[1]  .  .  .  .  .| <Missing> .  .  .  .  .| X31/5788
AWBURSTM[0]               | <Missing>              | X31/6044
AWLOCKM[1]   .  .  .  .  .| <Missing> .  .  .  .  .| X31/5789
AWPROTM[2]                | <Missing>              | X31/5790
AWPROTM[1]   .  .  .  .  .| <Missing> .  .  .  .  .| X31/5791
WIDM[3]                   | <Missing>              | X31/5792
WIDM[2]   .  .  .  .  .  .| <Missing> .  .  .  .  .| X31/5793
WIDM[1]                   | <Missing>              | X31/5794
BREADYM   .  .  .  .  .  .| <Missing> .  .  .  .  .| X31/6045
ARIDM[3]                  | <Missing>              | X31/5795
ARLENM[3] .  .  .  .  .  .| <Missing> .  .  .  .  .| X31/5798
ARSIZEM[2]                | <Missing>              | X31/5799
ARPROTM[1]   .  .  .  .  .| <Missing> .  .  .  .  .| X31/5800
RREADYM                   | <Missing>              | X31/6046
BRESPS[0] .  .  .  .  .  .| <Missing> .  .  .  .  .| X31/5808
RRESPS[0]                 | <Missing>              | X31/5813
PSLVERRDBG                | <Missing>              | X31/5847
===========[cortexr4_innowrapper]
====== Summary of Errors
Schematic     | Layout     | Error Type
           22 |          - | Unmatched Pin Labels
Do I need use globalNetConnect  for these nets ?   or any better solution ?
  • BobD
    BobD over 16 years ago
    I did a search for "SOCDB-2078" on http://support.cadence.com and found this:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11594216
    Could you have a look and let us know whether the solution helps?  It's saying that it's strange that an output of an instance is tied to power or ground.  If you really do intend for this to happen, I would look to make sure addTieHiLo was run and worked as expected.
    Hope this helps,
    Bob
