  3. Need a dbCommand to get names of objects with specific ...
  • Subscribers 95
  • Views 15873
Need a dbCommand to get names of objects with specific attributes
0007
0007 over 16 years ago
Hi All,
I want to know a command to get the names of objects with specific attributes.
For example, I want to get all instances with baseClass as block
dbGet top.cell.props.parent.baseClass will give the base classes of all the objects.
can I use some sort of  filter or command to get the pointers which point instances with the base name block.
Anil
  • BobD
    BobD over 16 years ago
    Hi Anil,
    I think you need to use dbGet's "-p" option to traverse back to the previous pointer and chain together a couple of dbGet commands.
    There's a good blog entry on this here from my colleague Kari:
    /blogs/di/archive/2009/08/12/useful-dbget-one-liners.aspx
    Hope this helps,
    Bob
  • kazad
    kazad over 16 years ago
    Hi Bob
    I was wondering how I can get the multi-cut via count with db command.
    Khandaker
  • anil chatrathi
    anil chatrathi over 16 years ago
     Hi Khandaker,
    you can use:
    llength [dbGet top.nets.vias.via.name *CUT*]
    Anil
  • kazad
    Hi Anil
    Thanks - it's working perfectly!
    Regards
    Khandaker
