  3. Free Hercules & Calibre DRC error viewer for dfII/Virtuoso...
  • Replies 32
  • Subscribers 98
  • Views 26546
Free Hercules & Calibre DRC error viewer for dfII/Virtuoso & SOC/EDI.
Stephane A
Stephane A over 16 years ago
Dear all,
Hercules from Synopsys doesn’t have a GUI to visualize the DRC errors in SOC/EDI.
So I created a Graphical User Interface that does it. Then I added support for Calibre(Mentor) and for dfII/Virtuoso.
The GUI is simpler than RVE or VUE, but it is very useful for a basic DRC error viewing job.
The features are:
  • View Hercules DRC errors in SOC/EDI
  • View Hercules DRC errors in Virtuoso
  • View Calibre DRC errors in SOC/EDI
  • View Calibre DRC errors in Virtuoso GDSII to ASCII: translate a GDS2 file in readable text format.
When will you want to use it:
  • You have a limited number of RVE or VUE licenses and want to allow more people to debug DRC errors at the same time.
  • You don’t use Calibre, you are not able to view Calibre errors but your fab. run Calibre as signOff and sends you the Calibre error files.
Validated with SOC8.1 EDI9.1 and IC5.1.41USR5
dibVue 1.0 .
The package "dibVue1.0.tar" is attached to this post.
Please read the following posts on this subject to get the latest release of dibVue.
Installation:
  1. Perl/Tk must be installed on your machine.
  2. Copy dibvue.pl, dibvue.il, dibcomMenu.il and GDS2.pm to an installation directory of your choice : <your_DIB_HOME_path>.
    Make sure “dibvue.pl” is executable (chmod a+x dibvue.pl)
  3. Set the Linux environement variable DIB_HOME:
    1. setenv DIB_HOME <your_DIB_HOME_path>, or
    2. export DIB_HOME=<your_DIB_HOME_path> for zsh shells
  4. Install dibVue inside dfII, 2 ways:
    1. Temporary install.
      1. launch icfb, and in the icfb window, type:
      2. load(“<your_DIB_HOME_path>/dibcomMenu.il”)
    2. Permanent install.
      1. Add load(“<your_DIB_HOME_path>/dibcomMenu.il”) in your .cdsinit file in your home directory. That’s it.
  5. Install dibVue inside SOC/EDI:
      1. on the SOC/EDI shell : source $env(DIB_HOME)/dibvue.tcl; dibvue;
      1. Put the two lines below in your “enc.tcl” file.
      2. uiAdd DiBcom -type menu -in main -label DiBcom
      3. uiAdd dibVue -type command -in DiBcom -label "dibVue" -command "source $env(DIB_HOME)/dibvue.tcl;dibvue"
Usage:
  1. How to start dibVue
    1. dfII/Virtuoso: open a Virtuoso layout view and click on “dibVue” in the “DiBcom” menu on the top right.
    2. SOC/EDI: open SOC/EDI, load a design, and click on “dibVue” in the “DiBcom” menu on the top right.
  2. Load Calibre DRC errors:
    1. Check the “Cali” checkbox
    2. Browse and find your Calibre .db text file through the “…” button on the “Text file:” line. A click on the “<>” button will edit the file with nedit.
    3. Click the “Load” button. Multiple loads are possible, the previous load is replaced by the new one.
  3. Load Hercules DRC errors:
    1. Verify that the “Cali” checkbox is unchecked.
    2. Fill the “Text file:” line with your *.LAYOUT_ERRORS file. A click on the “<>” button will edit the file with nedit.
    3. Fill the “Gds file:” line with your *.gds errors GDS file.
    4. Click the “Load” button. Multiple loads are possible, the previous load is replaced by the new one.
  4. After clicking the “Load” button, a summary of the DRC errors is displayed in the icfb window.
  5. Browsing and highlighting the errors:
    1. The left listbox of dibVue should be filled with the rules in error.
    2. You can now browse the errors by clicking on them (left and right listboxes).
    3. “Clear All” button: clears all the errors highlighted so far.
    4. “Hi rule” button: highlights all the errors of the selected rule.
    5. Check the “auto Zoom” checkbox if your want dibVue to zoom on the error you click on.
    6. Density errors in Hercules: the density errors can be filtered by density % when checking the “ratio Filter” checkbox and filling a percentage value between 0 and 100.
    7. The bottom text window displays the rule title and description.
  6. Misc.
    1. When loading Hercules DRC erors:
      1. “(no GDS)” appears next to a rule name if the errors markers comes from the text file and not from the GDS file. dibVue tries to display the errors even if they are hierarchical. This is a limitation of dibVue.
      2. “Nb err.: 20(24)  *” : the number of errors differs in the text file and in the GDS file due to hierarchy in the GDS structure. dibVue may not display all the errors. Warning, this is a limitation of dibVue.
    2. The Calibre mode supports loading results of “compare_gds” runs.
    3. dibVue is able to load the SHORT (shortest path) databases for both Calibre and Hercules.
    4. dibVue is able to translate a binary GDS file to a text file through the dibVue command line mode:
      dibvue.pl –help
      dibvue.pl -gds <my.gds> -ascii <my.gds.txt>
    5. The dibVue GUI can be started in standalone mode from a command shell:
      dibvue.pl
Command line:
dibvue.pl –help
Usage: dibvue.pl -top <top_cell_name> -txt <*.LAYOUT_ERRORS> -gds <EV_OUT.gds>
  -txt <*.LAYOUT_ERRORS> : Text file generated by Hercules. It contains the
                           DRC errors in a text format.
  -gds <EV_OUT.gds>      : GDS file generated by Hercules containing the detail
                           shapes of the DRC errors.
  -ascii <file.txt>      : Writes out the GDS in a text format in <file.txt> and exit.
  -dfII                  : Activates the dfII/Virtuoso/Skill mode.
  -help                  : This message.
Log in the icfb window when starting icfb:
DiBcom menu.
*          DiBcom dibVue Skill Interface.
*     An Hercules and Calibre DRC error viewer.
Log in the icfb/SOC/EDI window when loading the erros:
-I- Starting dibvue ...
Reading the Calibre db text File: drcmok.db ...
-I- top cell : -->w7_mergedok<--
Nb err.:   1000  Rule :        Off_Grid  --> Vertice is drawn off-grid.
Nb err.:   1000  Rule :        SkewEdge  -->
Nb err.:      2  Rule :         4.17C.b  --> Minimum P+ implant enclosure of P+ DIFFUSION (inside P_WELL or T_WELL) is 0.08um
Nb err.:      1  Rule :           4.17N  --> Maximum P+ DIFFUSION to nearest N+ pick-up spacing (inside N_WELL) is 20um (I/O, RAM, ROM, capacitor and diode are expected)
Nb err.:     11  Rule :           4.31H  --> The minimum overlap of IND block to inductor layer is 10um Only Inductor Top Metal is allowed in IND
Nb err.:      2  Rule :            4.1M  --> Minimum DIFFUSION density over 500um x 500 um areas is 20% in % moved in 250um increments across the chip
Nb err.:      1  Rule :           4.22G  --> The ME2 coverage must be larger than 25% for every 500*500um square
Nb err.:      4  Rule :         6Ab.ME6  --> Die corner rule 1, ME6 must draw with 135 angle
Nb err.:     13  Rule :         6.1A.M3  --> Maximum metal_3 width without slotting when length is greater than 30um is 20um except, between metal edge and slots spacing between slots bonding Pad areas
done
Best regards.
Stéphane.
dibVue1.0.zip
  • Stephane A
    Stephane A over 16 years ago +1
    A added a snapshot. See attached.
  • Mahesh Shetty
    Mahesh Shetty over 15 years ago +1
    Hi Stephane, Thank you for sharing your valuble efforts. I am using your script to load the calibre drc error. But the error window does not loading any markers. No idea what is the issue. Do I need to…
  • Stephane A
  • Mahesh Shetty
     Hi Stephane,
    Do I need to do any settings other than mentioned above.
    Mahesh
  • Stephane A
    Stephane A over 15 years ago
    Hi Manesh,
    I can help you but I will need more information from you to understand the environement you are using:
    • Are you using dibVue in SOC/EDI or in dfII/Virtuoso?
    • Which version of the Cadence tool are you using?
    • You say "I am using your script", did you have it ever work or is it the first time you are using it?
    • Can you describe more in detail at which step it fails? Is it when you click on the "Load" button?
    • Do you see any error message in the ciw or in the SOC/EDI text window when running dibVue?
    Besside this, the dibVue tool has been improved since the 1.0 release. I fixed some bugs and I added new features. I can build a new release if you are interested.
    Best regards.
    Stéphane.
  • Stephane A
    Manesh,
    If you can send me your complete Calibre error file (.db) or  a part of it I will try to load it in dibVue.
    Best regards.
    Stéphane.
  • Mahesh Shetty
    Hi Stephane,
    Please find the required info. ..
     -  I am using dfII/virtouso
     -  I am using ICFB 5.10.41_USR4.54.77
     - I am using it first time
     - Yes. I do have errors in the layout. But Load button doesn't load anything in the error window
     - No. I am not seeing any error message in the CIW. It just says "done"
    I can send you the <>.db file. I am not able to attach the file to this post. Can you please give me email id?
  • Stephane A
    Mahesh,
    The syntax of your .db file is not fully supported by dibVue. After fixing your db file it works correctly.
    Which version of Calibre are you using? Is it an other tool?
    Stéphane.
  • Stephane A
    dibVue snapshot.
  • Mahesh Shetty
     Hi Stephane,
    I am not sure about the exact version of the calibre. It might be latest calibre release.  Can script be fixed to tackle this?  Please let me know your views.
    Mahesh
  • Stephane A
    Hi Mahesh,
    Yes, I can fix the script.
    But the rule information at the bottom of dibVue will still contains the rule equations as they are included in your rule descriptions in the .db file.
    Would it be ok for you?
    Did you have a chance to make dibVue work with the fixed .db file I sent you?
    Best regards.
    Stéphane.
  • Mahesh Shetty
     Hi Stephane,
    Yes, I am able to load with your modified .db file.
    I am Ok with rule including the rule equation.
    Thanks for the help.
    Mahesh
