  3. negative delay backannotation
  • Subscribers 94
  • Views 21232
thescreen
thescreen over 16 years ago
hello forum
i am getting this while backannotating
ncelab: *W,SDFNL1 (..../UMK90LSCLLGDH_B01/verilog/uk90lscllgdh.v,42289|8): Attempt to annotate a negative value to a 1 limit timing check in instance (tb.i_vdt_top.spr_182.spr_gate3077), setting to 0 <..../vdt_top.max.sdf.gz, line 33318>.
    $hold( posedge CK &&&
whose meaning is
ncelab/SDFNL1 =
        Attempt to annotate a negative value to a 1 limit timing check.
        Negative values are only allowed in $setuphold, $recrem and the
        non-standard 2-limit version of $recovery.
at line 42289 of
uk90lscllgdh.v i see
    // removal
    $hold( posedge CK, posedge RB, 1.0, notifier );
i.e. i can find a  $hold and not $recrem.
i think the problem is how the library is written
    // recovery
    $recovery( posedge RB, posedge CK, 1.0, notifier );
    // removal
instead of
    // recovery and removal
    $recrem( ..... );
resulting in a backannotation of 0 instead of negative delay (ignmoring the warning may not help)
i got similar errors also on checks like
   $hold(posedge CK &&& (shcheckCKSDlh === 1'b1),
ncelab: *W,SDFNL1 (..../uk90lscllgdh.v,32163|8): Attempt to annotate a negative value to a 1 limit timing check in instance (tb.i_vdt_top.i_vdt_core.i_access_if.i_iibus_reg_file.regfile_ro_reg_47__1_), setting to 0 <..../sdf/vdt_top.max.sdf.gz, line 142092>.
could you suggest a workaround for this before i contact the library vendor
  • thescreen
     i found the issue: it was a legacy OVI 2.1 SDF file being backannotated ina netlist having recovery system tak. switching to OVI 3.o solved the problem
