  3. RTL compiler - elaborate problem.
  • Replies 9
  • Subscribers 95
  • Views 7712
sandeepsuhas
sandeepsuhas over 16 years ago
Hi All, When I run rtl compiler I am facing the following error: Error : Invalid operating_conditions name. [LBR-32] [elaborate] : Library has no operating conditions named 'tt_1p2v_25c'. : Use ls to see the valid operating_conditions in the libraries. Error : Error when processing libraries loaded into domain. Cannot continue unless all domains' libraries are OK. [LBR-115] [elaborate] : Error when processing domain: /libraries/library_domains/_default_ Failed on elaborate -libpath /home/ssriram/project -libext .lib mult.v But the above said operating condition is present in the library. Any help would be appreciated. Regards Sandeep.
  • diablo
    diablo over 16 years ago
    The first I would check whether operating condition is defined in your tt_1p2v_25c.lib file as below
      operating_conditions(tt_1p2v_25c) {
        process    : 1;
        temperature    : 25;
        voltage    : 1.2;
        tree_type    : balanced_tree
  • sandeepsuhas
    Hi , Thanks for the reply. but i have it in my .lib file. Here is the print: operating_conditions(tt_1p2v_25c) { process : 1; temperature : 25; voltage : 1.2; tree_type : balanced_tree; power_rail (VDD, 1.2); power_rail (VSS, 0.0); }
  • sandeepsuhas
    How should I go now.
  • diablo
    The first thing this question will be relevant in logic design forum instead of digital implementation forum .
     Looking at your error, elaborate -libpath /home/ssriram/project -libext .lib mult.v, is confusing.
    Usually we have
    set_attribute lib_search_path home/ssriram/project/
    set_attribute library tt_1p2v_25c
    read_hdl *.v
    elaborate $design
    I am not sure what are your commands . It will help if you run each command in your script line by line in RC prompt and see which command is giving you error.
  • sandeepsuhas
    Hi Diablo, Here are the commands which I used for elabortion. set_attribute lib_search_path { /home/ssriram/project } set_attribute script_search_path { /home/ssriram/project } set_attribute hdl_search_path { /home/ssriram/project } set_attribute path /home/ssriram/project # target libraries #create_library_domain {nor} set_attribute library scmetro_cms9flp-rvt_tt_1p2v_25c.lib ./ # Reads the rtl files and syntax xhecks set file_list mult.v read_hdl $file_list elaborate -libpath /home/ssriram/project -libext .lib mult.v Regards Sandeep.
  • diablo
    Did you try running each command in a RC instead of running whole script? Is it the "elaborate -libpath /home/ssriram/project -libext .lib mult.v" that's giving you error? what happends if you just do "elaborate <top level of your design>"  ?
  • sandeepsuhas
    Hi Diablo, As you mentioned I ran individual commands, the problem is in elaborate command which is not able to take the operating_condition attribute. Regards Sandeep.
  • grasshopper
    grasshopper over 16 years ago
    Hi sandeepsuhas,
    I believe you are using the commands incorrectly
     rc:/> elab -h
      elaborate: elaborates previously read HDL files and creates corresponding design and subdesigns
    Usage: elaborate [-parameters <string>] [-libpath <string>]+ [-libext <string>]+ [<string>+]
        [-parameters <string>]:
            specifies a list of parameter/value pairs for top-level Verilog module or VHDL entity
        [-libpath <string>]:
            defines Verilog library search path
        [-libext <string>]:
            defines Verilog library file extension
        [<string>+]:
            the top-level Verilog modules or VHDL architectures to elaborate
    You can see in the usage that -libpath refers to the Verilog library search path and not the Technology libraries hence your -libext should certainly not have .lib in it.
     I normally set libraries using
     set_attribute library <library file list>  /
     Also, RC questions are probably better suited for the logic design forum I think.
    good luck,
    gh-
  • sandeepsuhas
    Thanks for the mail, I tried the above combination it is not taking the operating condition correctly. As per your comments I will post the query in logic design
