  3. editPin slows down with each new pin
  • Subscribers 92
  • Views 14064
dfick
dfick over 15 years ago
 I'm using editPin to place pins in our top level design but it gets slower for each pin it adds. It's a 3D design so editPin is the only command that I know of that can place pins in the middle of the design, and we have tens of thousands of connections from this layer. Does anyone know how to speed this up?
  • BobD
    BobD over 15 years ago
    Could you let us know which version you're seeing this on?
  • dfick
     @(#)CDS: First Encounter v08.10-s273_1 (64bit) 06/16/2009 02:26 (Linux 2.6)
    @(#)CDS: NanoRoute v08.10-s155 NR090610-1622/USR60-UB (database version 2.30, 78.1.1) {superthreading v1.11}
    @(#)CDS: CeltIC v08.12-s254_1 (64bit) 06/11/2009 13:50:30 (Linux 2.6.9-67.0.10.ELsmp)
    @(#)CDS: CTE v08.10-s204_1 (64bit) Jun 10 2009 13:59:07 (Linux 2.6.9-67.0.10.ELsmp)
    @(#)CDS: CPE v08.12-s010
  • dfick
    Since the vast majority of the pins were feeding through from submodules, I found the simplest solution was to mark those nets as special so that they would not be routed, and then set placeDesign to not automatically place unplaced pins. Any unplaced pins at the end would by default be placed directly on top of the submodule pin (the GDS label at least). This also means that every single non-feedthrough pin needs to be placed explicitly, which is not a problem in my case.
     Here is the code I used:
          # Mark F2F and B2B pins as special so that they're not routed by nanoroute
        foreach_in_collection net [get_ports {bm_bc* core_TDO* mode_4core* etc}] {
            setNet -net [get_object_name $net] -type special -setTermSpecial
     setTrialRouteMode -ignoreNetIsSpecial false
    setPlaceMode -placeIoPins false
