  3. reporting multicut via
  • Subscribers 93
  • Views 19522
archive over 19 years ago
Does any one know the command to dump out the number of multicut vias in a design using nanoroute (Encounter).
Originally posted in cdnusers.org by mvvijay78
    You should see a couple of lines in the log like the following:
    #Total number of vias = 1928911
    #Total number of multi-cut vias = 918149 ( 47.6%)
    - Kari
    Originally posted in cdnusers.org by Kari
    Thanks kari.Currently we are doing the same. We are looking into the log file of nanoroute to grep for the number of multicut vias .  But wanted to know if given a routed database is there any command which could dump out the same info.
    There's a gift script that comes with your FE install : userRptViaStats.tcl This dumps via counts to the cmd window for all vias individually (regular & special). You can source and run this as part of your batch run script, or in FE after restoring a routed db.
    You could tweak the gift script a bit to get what you want.
    Skip special nets so you don't get the power grid via arrays...
    if [dbIsNetSpecial $netId] { puts "Skip Special Net: $netName"
    Add some statements to get number of cuts in each via as it loops though the route segments...
    set xCuts [lindex [dbInfoViaCellRegularCuts $viaPtr] 4]
    set yCuts [lindex [dbInfoViaCellRegularCuts $viaPtr] 5]
    Then only list the multi-cut vias...
    if {$xCuts > 1 || $yCuts > 1} {
    incr multCutViaCount
    if [info exists viaList($viaName)] {
    If you want the script output to go to both the command window and the log file, you need to change the "puts " to "Puts" (use Upper-case P)...
    Puts "Total Multi-Cut Vias: $multiCutVias"
    -Rich
    Originally posted in cdnusers.org by rjkleinstick
    Thanks! Rich, your post indirectly helps me a lot!
    I have been tried to find way to iterate all the vias in SOCE until the day I see your post.
    Many thanks!!
    Originally posted in cdnusers.org by eminemshow
  • shvd
    shvd over 7 years ago in reply to archive
    Is this script complete?
    I need a full script if possible.
  • shvd
