  3. "generate statements" in RTLCompilation
  • Subscribers 94
  • Views 870
Kamal Kundu
Kamal Kundu over 16 years ago
 I have used generate statements exhaustively in RTL which were easily understood by DC. But I am wondering how can we utilize same verilog code (with generate statements) in RTL Compiler.
The code example is as below :
  generate if (xyz == 1'b1) begin :
  module M( .A(A), .B(B))      ;
   end
   endgenerate
All ideas/suggestions/solutions are welcome!
  • grasshopper
    grasshopper over 16 years ago
     Hi Kamal,
    you must have a typo being that you used generate statements exhaustively. The code provided is not compliant with LRM hence it will likely not compile in RTL Compiler or most other self-respecting synthesis tools.Can you clarify what your module declaration is trying to do? It does not even have a proper port declaration (BTW, port declarations are ilegal in generate blocks)
    Following is a simple example you can try that illustrates what I think you are trying to do. Just read with read_hdl -v2001 or read_hdl -sv, elab, and synthesize and should produce expected results
    module top (
                  input wire clk, in,
           output wire out
       parameter xyz = 1'b1;
       generate
              dummy d1 (.in(in), .clk(clk), .out(out) );
           end
           else begin
              assign out = in && clk;
           end
       endgenerate
    endmodule // top
    module dummy (
                    input wire clk, in,
             output reg out
    always @(posedge clk) begin
           out <= in;
    end
    endmodule
    drop an email if you still have questions
    regards,
    gh-
