  3. Stream Out from Virtuoso
  • Subscribers 94
  • Views 16170
mingfatty
mingfatty over 16 years ago
 Hi there,
I have a design which link to my own created library in Virtuoso and wiling to send out the design for fabrication but during my test run (stream-in in another machine) i found out that the gds2 file that i stream out is not containing any layout from my own library and i do not know what should i do to include my reference library information to the gds2 file. please advise on this.
 MF
  • mikhail
    mikhail over 16 years ago
     H,
    You need to check options form on Stream Out form.
    If you should see "Translate Entire Hier" on General tab and on Libraries tab you need to get free list of reference libraries because cells from ref libs are just referenced in resulting gds.
    Hope this helps.
    Mikhail.
