  3. RC extraction
  • Replies 12
  • Subscribers 93
  • Views 21072
RC extraction
archive over 19 years ago
Hi all, I need some help.Now I am trying to model power of buses. But I don't know how to get the total RC value of selected nets.(there are thousands of nets so it is impossible to do it one by one) I wonder if there is a way of doing it. and another thing I want to ask is that all nets capacitances are 0. I wonder if it is right. Thanks
Originally posted in cdnusers.org by justinchen1980
    archive over 18 years ago
    Justin,
    The fields in dbNetExtrRCSummary stand for:
    cap_cnt,total_cap,xcap_cnt,total_xcap,res_cnt, total_res
    For your previous inquiry regarding how to get the value for all of the nets, I believe you're seeing that dbNetExtrRCSummary does not support wildcard matching for the net names you give it. You can help dbNetExtrRCSummary along by imbedding it within a foreach loop where, by some other means, you've captured the nets you're looking for.
    In my design, I have a bussed net called "r697". It looks like this:
    [DEV]encounter 21> dbFindNetsByName r697*
    {r697[15]} {r697[14]} {r697[13]} {r697[12]} {r697[11]} {r697[10]} {r697[9]} {r697[8]} {r697[7]} {r697[6]} {r697[5]} {r697[4]} {r697[3]} {r697[2]} {r697[1]} {r697[0]}
    Once I capture it by wildcard, I can then loop through and call dbNetExtrRCSummary iteratively for each net:
    [DEV]encounter 22> foreach net [dbFindNetsByName r697*] {Puts "[dbNetExtrRCSummary $net]"}
    42 18.7058 0 0 54 149.339
    53 28.6919 0 0 65 168.797
    39 11.8179 0 0 50 118.105
    47 25.3172 0 0 57 157.352
    40 16.1687 0 0 50 137.919
    33 16.3909 0 0 46 124.05
    39 18.2286 0 0 51 138.262
    41 14.0841 0 0 56 153.221
    41 14.6328 0 0 51 122
    50 20.0135 0 0 63 152.456
    38 13.516 0 0 51 132.627
    44 19.1988 0 0 57 158.185
    45 23.8199 0 0 54 148.814
    53 22.2221 0 0 65 163.052
    41 19.9921 0 0 55 160.046
    50 23.8562 0 0 61 180.404
    If the pattern you seek to match is more complicated than simple wildcarding will allow, you could use TCL's generic "regexp" to match the name. Or, you could leverage the dbGet command's support for regexp pattern matching. Say you wanted to get just the bits that start with "[1":
    [DEV]encounter 31> dbGet -regexp top.nets.name {r697\[1}
    {r697[15]} {r697[14]} {r697[13]} {r697[12]} {r697[11]} {r697[10]} {r697[1]}
    [DEV]encounter 34> foreach net [dbGet -regexp top.nets.name {r697\[1}] {puts "[dbNetExtrRCSummary $net]"}
    From the discussion in this thread it is clear that there is room for improvement in the way RC extraction information is accessible via TCL. As improved capabilities become available in this area, I will post back to this forum with an update. Thanks to all who posted their suggestions on this topic- great discussion!
    Hope this helps,
    Bob
    Originally posted in cdnusers.org by BobD
    thanks ,bob , I got it done by writing a script repeating the command, but your way seems better.
