  3. RC extraction
  • Replies 12
  • Subscribers 93
  • Views 21071
RC extraction
archive over 19 years ago
Hi all, I need some help.Now I am trying to model power of buses. But I don't know how to get the total RC value of selected nets.(there are thousands of nets so it is impossible to do it one by one) I wonder if there is a way of doing it. and another thing I want to ask is that all nets capacitances are 0. I wonder if it is right. Thanks
Originally posted in cdnusers.org by justinchen1980
    archive over 18 years ago
    if you use SOCE internal rc extractor, you can use "dbNetCap [dbGetNetByName your_net_name] to report the cap. I am not sure/how if you can report the R this way. If you use a external spef using spefIn spef_file, then you can use "dbNetExtractRCSummary [dbGetNetByName your_net_name] to report both R & C.
    li siang
    Originally posted in cdnusers.org by lisiang
    lisiang:
    There is really no way the get the R of a single net in SOC-E, sigh..
    Originally posted in cdnusers.org by eminemshow
    way to wrok around the R problem
    1) extractRC
    2) rcOut -spef temp.spef
    3) spefIn temp.spef
    4) dbNetExtrRCSummary [dbGetNetByName your_net]
    and that should give you toal Cap, total xCap and total R
    li siang
    Posted By lisiang on 11/26/2007 3:02 PM
    1) extractRC
    3) spefIn temp.spef
    li siang
    Thanks, li siang!
    Thank you guys very much, I will try it .
    I have a question for dbNetExtrRCSummary [dbGetNetByName your_net_name]
    what is the syntax for" your_net_name", if the nets are from ahbso[83] to ahbso[0], how should I input? I did like
    "dbNetExtrRCSummary [dbGetNetByName ahbso]" but there was an error.
    You can try to use {} charactere around you net name:
    dbNetExtrRCSummary [dbGetNetByName {ahbso[0]}]
    Pat.
    Originally posted in cdnusers.org by bougantp
    thanks, that's helpful
    But still that's for single net , how can I get the the value for all the nets ? for example from ahbso[343] to ahbso[0].
    does anybody know about what does the values given by  dbNetExtrRCSummary stand for :
    like 17 62.937 0 0 16 204.094, I know 62.937 is capacitance and 204.094 is resistance, what about the others?
